OccupantRJ
Upon bringing home my 20" Monarch woodcutting band saw, I set about to improve it's condition a little. I had the saw only a short while before the flood got me, so had not used it much. I had noticed, however, that the blade was tricky to track properly, so I decided now was the time to find out why. After some disassembly of the tensioner section of the saw, I found that the upper wheel mount tracking trunnion had an ear broken off the cast iron body. Since this ear is under a decent amount of load when the blade is properly tensioned, I felt that welding or brazing was not the way I wanted to go. Instead, I chose to do a purely mechanical repair, as pictured below. This is where the milling machine comes into play. Sometimes in repairs, you have to remove and give up something to get something. This is one of those cases. The back of the trunnion was milled away partially to accept a steel substitute for the cast ear. By milling back into the parent part this way, the ear will be under a cantilevered load in use. A steel piece was milled and drilled for countersunk bolts for attachment. The end of the piece required a radius for the rocking action of adjusting the trunnion, so it was also milled on the Bridgeport. I needed a 2-1/2" radius, and lo and behold, that happens to be the radius swing of a Bridgeport 6" milling vise, at the fixed jaw. I left the swivel bolts a little loose, and using the vice as a swinging radius cutter, advanced toward the end mill a few thousandths at a time as I swung the vice. The result is what you see below. Doing this type of emergency repair in the factory is how I make my living, and it's always challenging and interesting. Hope you all enjoy.
