Why ?
Why do Armstrong, Craftsman and others make their 3/4" breaker bar the same length as their 1/2" bar ?
Are they using the same forging die for the handle and just changing the head ?
PBCampbell
WV
I'm pretty sure the handles are always thicker to handle the increased load that is likely to happen but finding long length breaker bars in 3/4 is difficult if not impossible. I have 24" 1/2 drive breakers but the longest 3/4 I've seen is 18".
ATC
VA
Northern Tool always has 40" bars on the shelf...
I don't think they make them long because of weight, and because they would bend.
A solid bar of steel will bend much easier than a hollow pipe. And when you are talking about the torque numbers of 3/4"....it's easy to do.
supersteve
Camas, WA
PBCampbell
WV
Say what?
I can guarantee my own ability at bending a "tube" opposed to a round solid given the same material and outside dimension.
KinzeMech
You can always put a pipe on it to make it bigger, but you can't practically make it smaller to work around obstructions.
I'm pretty sure a 3/4" breaker bar is made with the intention of piping it. Why else do they make the handle fit so nicely in a pipe?
Sterff
PA
I wondered this same thing a year or two back. I just sucked it up and got the Snap-on setup, which is to say a ratchet head, breaker head and 36" handle. This may be too rich for your purposes.
http://buy1.snapon.com/catalog/tools.asp?tool=&Group_ID=674954&store=snapon-store
http://buy1.snapon.com/catalog/item...roup_ID=674949&store=snapon-store&dir=catalog
http://buy1.snapon.com/catalog/item...roup_ID=674950&store=snapon-store&dir=catalog
You can get a williams head ( basically the same thing) for alot cheaper.
RedneckWelder
The Ghetto Kingdom of Methlandia
I asked about this some months ago. I work in a shop where cheater pipes are verboten.
They leave them short to fit nicely in the box and also a lot of people will put a cheater pipe on them.
There are some companies that make 36" + ratchets and breaker bars, we use the Titan 1" drive 42" bars at work, throw and adapter on them for 3/4 or even down to 1/2"
Oh, and I was putting enough torque on one of the Snap On handles to very noticably bend it
And believe me, I use it enough to make it worth having a long 'un.
supersteve
Camas, WA
You can get a williams head ( basically the same thing)......
Good point, this is undoubtedly the way to go for most folks. I'm on toolsdelivered but I'm not seeing a 36" handle. I wonder if Williams has one or if you can use the Snap-on one. Or you could make your own.
.....for alot cheaper.
Then again, I'm a cheapskate. It's not like I paid full retail for this thing.;)
Sterff
PA
The only problem with the Williams head is that it requires a 13/16" handle, where as the Snap-on, has a 15/16" handle. Snap-on used to make longer handles in the 13/16" size if you can find one. If you have to just slide a pipe over the 20" handle. I have a tekton breaker bar as well too.
I bought mine from here...
http://www.industrialsupplydenver.com/wi3rerachmai.html
Wakefield
Arlington VA (but would like to get out to country
The pin in the S*K is thicker-looks to be 9/16"? than the one in the 40 inch long Titan (which is a bolt rather than pin) that looks to be an M10 but is not a true axle bolt (doesn't have the definite step to a larger diameter than the thread diameter) both 3/4" drive bars
