Wilton 835 another electrolysis vise resto
georgiadave
Marietta, Georgia
The date of manufacture is on the slide keyway. I can see the stamping in one of the pictures, but can't read the date. It is an old vise, as it says Chicago rather than Shiller Park.
mkirkpatrick
Big Sky Country
Thank you, that rocks, I was wonder how and what you did, you can pick up a power unit off a old computer for pennies. I second would you show us the set up.
Again, thank you great thread.
whelenfan
Central NJ
Man do I love vise threads. I have a Desmond Simplex that came with the house when we bought two year ago and since joining this forum I have contemplated breaking it down and giving it a serious cleaning.
spongerich
Monroe, NY
A automotive battery charger works fine
Lots of newer battery chargers need a load on them to supply a decent number of amps. You can hookup an old battery and use it, but an old PC ATX power supply is ideal. They'll put out between 10-40 amps at 6 or 12v and most have a small fan to keep them cool.
You can also often get one free (or nearly free) so there's no worry if you toast it.
To setup for electrolysis, cutoff the connectors.
- Strip and connect all the black wires together (ground)
- Strip and connect the green wire to the bundle of black wires (this is connected to the switch on a PC. You need to ground this for the PS to stay on.)
- Strip and connect all the yellow wires together (+12v)
- Strip and connect all the red wires together (+5v)
Connect some clips to your wire bundles and you're ready to go.
If you power supply doesn't have an on/off switch you can route the green wire through a switch and use that.
06wt
chicago 434 UNION CARPENTER
Nope no smell, but the process does produce a lot of hydrogen gas, doing outside is the best.
Spongerich cover the power supply questions pretty good wen I get home today ill post detailed pics.
