Wiper Arm Pullers?
Hakeem
Chicago
What’s the goto wiper arm puller these days? Lisle makes one but the arms look a little flimsy:IMG_2313.jpeg
This one from “Glass Technology” is a little pricey at $52 but looks stout:
Glass Technology Windshield Wiper Puller Rod Design
https://www.amazon.com/dp/B013IP94BE?tag=atomicindus08-20
Anybody with personal experience with these or other models they can suggest? I have an otc front end kit with tie rod seperators and the like, but sometimes they are too bulky to fit under or around the wiper arm.
KnurledNut
n/a
I can usually wiggle the tapered knibbler bushing ones loose, but for the stubborn ones, I’ve use a battery terminal puller. Seems like I remember using a faucet handle puller before too. The Glass Technology one is supposed to be the bees knees but I have got by without it.
drtyler
signcrafter
I have the lisle one and it works for most. I'm on my second one, the little tip broke off the arm on one a few years back. I did run into one arm I could not get off on a transit connect, must have been put on with an impact or something and it's at a weird angle and recessed so can't get other pullers in there. I bought the OTC heavy duty one after that but it's also limited to what it can get onto because heavy duty means it's pretty big. https://www.amazon.com/OTC-6676-Heavy-Duty-Windshield-Puller/dp/B004CGRQGE/?tag=atomicindus08-20
I have this set in my list to get to see if it helps with the next stubborn one, https://www.amazon.com/dp/B0D83K5YPG/?tag=atomicindus08-20. Not sure if it will fit on some but figure it be nice to have for another option. I also have the glass technology one in my list. When I run into something I can't get with the tools I have I end up ordering everything I can find so I don't have to struggle next time.
PassnThru
Bowling Green KY
I have the one pictured by the OP - I've used it about 3 times and it worked well. I really like the knob at the top that puts tension on the arms so they stay in place. Only problem was on a rear wiper where it just barely fit as there is not much travel built into it. The T-bar is pretty flimsy but hasn't been a problem for me. Add some penetrate and some vibration to the mount and it will pop them off.
geneg
Midwest
The first one pictured used to be sold as a top post battery terminal remover. Always worked well for that. Put no downward pressure on the case like some of the post lifters.
djbmw
Ottawa, Ontario, Canada
I dont typically need to use a puller - just use my hands. However, if the fitting is tappered,... OR severely corroded, I've used the small puller in my gear puller kit (picture attached)
PassnThru
Bowling Green KY
Yes - I have the Lisle one (54150) and the package says 'Battery Terminal & Wiper Arm Puller'. I bought it so recently that I still have the package on my workbench.
geneg
Midwest
Mine was issued to me in the late 70's or early 80's. So- I don't have the receipt or the packaging.
drokihazan
I have an older OTC one that looks a lot like the Lisle one. It's worked fine for wiper arms and corroded terminals for me.
Outlier
GA
I believe the Lisle 54150 or Lang 202 are the best starting points for new tools. You can find the Snap-on CJ92 for about the same price used and it's likely more durable.
I have the Schwaben 8-piece wiper arm puller set, but I have never used it. The Lang 202 has done everything I have needed it to do.
