Wire stripers
Bigblue&Goldie
Craftsman Professional 73573. Made by Stride-Imperial.
Those are the strippers I mentioned above. USA made at a great price.
MaineGuide
Maine
I really like my Klein 1010 multi purpose tool for the little electrical work that I currently do. I'm hoping to hone my skills a bit more and will be looking into separate tools for stripping and crimping.
Brownsfan
Cleveland Ohio
Ideal Strippers & Klein Crimpers. Got this advise from an old timer retired from the marine electrical business.
I probably have 3 of those klein crimpers. Probably have had 15 or so over the years. I never broke or worn out any. I.would lose them. So I know always have a back up. They are the best plier style crimper IMHO.
Nele
Ideal strip masters are sweet, you can buy different inserts, I also have a pair of automatic ones made by Irwin
lightning02
Alot of people say the ideal crimpers are better then the klein? I'm in the market for a new pair and can't decide which of those 2 to pick.
Brownsfan
Cleveland Ohio
I chose the kleins based on 3 factors. 1. Readily available at Home depot and I can go get them if I loose a set. 2, The non- insulated die is in the front. 3. Slimmer design. I CANT be without crimpers. I use them every day ALL DAY. If I leave a set in a car and need a new set I can just got to HD. Being used in a automotive environment the slimmer design comes in handy. Just my opinion but I have been using them since 1996 with zero failures but MANY have been donated to customers under seats and in trunks and various other places.
mikebaker1129
Huffman,TX
I have a pair of US Craftsman combo strippers that I use at work. I'm pretty sure they're made by Klein for Craftsman.
Never had a problem with them in 5 years. The strippers work awesome and it cuts anything I need it to. I like that the cutting/stripping area is at the tip, it helps when I'm in tight spaces doing wiring repairs.
This^
ChrisLS8
I hate hate hate the combo tools. I use 909 for crimpers and 908 and 958 for the strippers for Channellock
Brownsfan
Cleveland Ohio
I use insulated ends more then anything
If that is the case then the Ideal would be the choice for you. I really cant speak to the quality and durability of the Ideal because I have never even seen them. I tend to buy tools I can touch and feel first. I don't buy many tools online.
Jarhead0408
Who knows?
Those look identical to my Klein 1010's.
sberry
Brethren, Michigan
I go with the guys on the T stripper. I actually used them side by side against the Kliens the other day, the Kliens were older but the t's worked so much easier and fit the wire better.
E
E.Marquez
Kempner Texas
I agree :rocker:
I like the ideal strippers better than my blue handled klein strippers:rocker:
Not if your not looking for Auto strippers :headscrat:thumbup:
For me the Ideal strip masters are useless in many cases and not need in the rest.
Thanks for the suggestion though. :thumbup:
E
E.Marquez
Kempner Texas
I have a set of Klein 1005
and Ideal 30-429
I like them both for the cheap(er) plastic insulated terminals.. but they tend to cut into the softer heat shrink tubing on better heat shrink/ insulated type terminals.
My Blue Point ratcheting crimpers with interchangeable jaw sets does a better job on those, and is the only way to go IMHO for open barrel terminals and pin terminals for weatherpak and other OEM plugs.
E
E.Marquez
Kempner Texas
Well too late now :D but if im not happy with the new Klein I'll try the ideal next.. I never met a tool I did not like (or at least want to buy and try)
Thanks :thumbup:
Buster21
Idaho
I to like the Klein crimpers and use them just about every day, But I also like the T&B WT111M crimpers. I'm old fashioned and still use my basic Miller 100 wire strippers. When you use them enough you go by feel and never use the adjustable notches, I set them so I can just see light through the hole and lock them down, then just feel when it goes into the insulation.
