Denwood
I’m with Wyliediesel...for sure use the Nano 5 ACs. I don’t use Ubiquiti WI-FI access points at home as the controller software is a PITA if you’re only using one or two access points. On the commercial side I do use them as you can manage a multi site network, firmware updates etc all in one spot.
So use two Nanobeam 5 AC (gen2) for your wireless bridge, but consider findIng an AC class 1200 or better access point for your barn. Any WIFi extender with wired access point mode will work. I like the netgear EX7000 for this as it also has 5 gigabit LAN ports. These come in handy if connecting security cams etc at the remote site.
Regardless, make sure your Wi-Fi access point has gigabit ports to connect to the remote Nanobeam5 AC...otherwise everything at the remote side will be limited to 100Mbit.
I have one of these inexpensive APs in my shop: https://www.tp-link.com/ca/home-networking/range-extender/re450/
It only has one Ethernet port, but it is a gigabit port. If using with a Nanobeam 5AC , you would plug that into the remote antenna’s Ethernet port and set the TP link to access point mode. That setup gets you ~400Mbps on a newer iPhone assuming your ISP can provide it.
Btw, glass will impede signal on these. I did some testing with a redundant system using four Nanobeam 5ACs and in the initial stage I had a linked pair inside at both ends. I did get a connection, but it was slow. They need to be line of site outside. That system works well btw as a redundant failover (2 parallel bridges). Users don’t even notice a failed link / swap.
