gjz30075
Home D has this brand in plastic and two different types, identified by the color of the packaging. The channel packaged in blue is a flat oval but without any way to attach it to the wall or ceiling. I'm guessing it gets nailed or screwed to the surface. The channel packaged in green is more rounded and has a peel off sticky on the back.
I plan on using 14-3 wire in the channel (black, white and ground, all wrapped together in a flat pkg). Is there any reason to pick one channel (and associated elbows, boxes, etc) over the other?
If I go with the flatter oval channel, would simply double sided tape work to hold the channel on the ceiling, or wall?
