Wiring a 220 Air compressor help
macombvan
I have a 3 1/2 HP 230v. 15 amp air compressor I need to wire in. I have a disconnect box that I had my old welder wired to that has #6 wire coming from a 50 amp circuit breaker in the main box. Can I use that circuit, or do I have to rewire with a smaller gauge and smaller breaker/ Any help would be great.
macombvan
Thanks. What size breaker should I use and what size wire from the disconnect box to the compressor?
K13
St. Albert, AB Canada
I just bought the same compressor today and have to figure out the wiring as well. Can I hardwire into an existing electrical box that has the right wire run?
bsaint
Manchester, CT
I would just leave the 6 ga. The only reason why we dont use wire that rated for too much higher than the desired current is cost of copper. 6 ga is overkill but perfectly fine.
Norcal
Is the disconnect fusible, or non-fusible? If it's fusible just use a lower rated fuse.
