Wiring help desperately needed! Weaver AFH-72
Payne
Nashville
I have a Weaver AFH72 that I took apart several years ago to restore & just got around to putting it back together. Unfortunately, I threw away the old wiring and can’t remember how I had it wired! There are only 3 wires to connect, a black, green & white. There are also two black wires conn together separately, to place motor in high position. I replaced the up & down switch and don’t know how to connect it to the power box. There are 3 screws in the switch. I’ve spent hour/days trying to research this & can’t find any information online. Would some with a similar lift please take a couple pictures of the inside of your power box and the inside of the the switch & send them to me? It would be a lifesaver! I’m in desperate need of my lift to repair my wife’s car..
P
Payne
Nashville
I have the wires marked. My issue isn’t so much the 220 wiring. My issue is wiring the up/down switch. When I start the lift, in rises directly to the top & wants to continue. I need to wire the switch to control the movement.
P
Payne
Nashville
I finally found my pictures, I knew I’ll took some. Unfortunately, it won’t allow me to post the picture regarding the up/down switch wiring. Hopefully this will help someone down the road..Thank you everyone for your help!
egdede
Thanks for following up. I'd like to think that ventually someone would have helped you : )
