Wiring Question
clonestocker
Can Romex be used in open stud walls in my garage? I was told that the wire needs to shielded wire. 2012 IBC. I think plan review missed a few think and I don't want to fail a rough in innspection. thx matt
pattenp
Virginia - USA
Local codes aside, yes as long as the wire is run along sides of studs and along running strips/boards where needed for protection. It is best to check with local inspectors.
Terry D
St. Louis, MO.
As already said, local codes vary. Even if allowed, i would never run romex perpendicular to the studs, unless its up high. If its going to have the walls covered, that thats a different story
Sent from my SM-G960U using The Garage Journal mobile app
Norcal
Shielded? If your talking about products like MC cable they are subject to the same requirements as NM cable that they be protected from physical damage.
readhead
Durango, Co.
When we wire our sheds with romex all runs are vertical on a stud. Nothing is horizontal. We also use metal boxes and metal covers on all the devices.
C
clonestocker
After talking to the inspectors this morning I was told that I can use MC cable in place of romex. I will double check thou. thx matt
readhead
Durango, Co.
Even with MC you cannot have any horizontal runs unless the walls are sheeted with something to protect the wire.
alfredeneuman
Fullerton, CA
He's on the 2012 IBC. The rules for MC might be different than the NEC.
Calling pattenp:) (He's on the IBC too)
nadogail
Coronado, CA
The whole idea is to protect the cable from physical damage. The NM Cable, colloquially called Romex, in my garage, where exposed, can only be reached by a person standing on a ladder.
pattenp
Virginia - USA
