I think the HF $200 was the most popular for DIY to small wood working shops.. I just recently got one off Craigslist for $100 with a dust loaded filter. I am hosing the dust off now for past few days. but it will work fine only a single stage setup at current moment.
This HF model. I think off HF coupons it went down as low as $150 sometime.
and people go either upgrade the filter or make it a dual stage dust collector. maybe both both. This is a MERV 10 filter, they have 2 other better ones for a bit more...
There is an impeller mod upgrade people also done to it extra $150 for the impeller that fits, it's one of the youtube videos...
you can look at Oneida Air, now (new lines) they have a collections of pro dual stage setups as well.. if you just wanted something working out of the box.
This youtube guy stumpy nubs have a few good videos on dust collectors
Dogdog
HF doesn’t ship to Canada but that is a good price with coupon for a dc. Once you start adding up the extra costs and labour to improve the characteristics of the dc would you really be ahead?
I did look at Oneida and quickly found they were out of my league price wise. Wonder if they are part of the silverware people?
Thanks for the homework will check out this stumpy guy.
Oneida ended up at the top of my list after a ton of research. I didn't buy one though. It's a big investment to buy a quality machine and all the piping, gates and hardware.
I ended up with a Dust Deputy coupled with a dedicated Ridgid shop vac on a mobile cart I built. It really isn't very efficient for airborne dust particles but it does keep the sawdust manageable.
Lardy
Oneida keeps popping up and definitely is pricey. You must have covered quite the volume of info when doing you research.
Haven’t ran across Dust Deputy and having a dedicated vac would be a good idea. You should see what I did for a temporary catch basin for saw dust under my table saw. I took a vinyl washtub cut a hole for my old Craftsman vac. Found some foam for a seal and mounted it under the saw. Sealed off all or most of the possible air losses and cut some lumber. Works half assed but eliminates saw dust all over the floor. I’ll probably be safe until my wife goes looking for her outdoor wash tub in the spring.
Set aside a few hours of time:
http://billpentz.com/woodworking/cyclone/
My thoughts:
First and foremost, you need to determine what machines you have now, and what machinery you will be adding in the future. All woodworking machinery produces a lot of dust. Some produce a lot more than others. And the type of dust varies. Sanders produce the finest dust, and it's difficult to contain. Planers/jointers produce a lot of chips, and they are the easiest to contain. Saws... Well this varies with machine design. Most home machines aren't designed with dust collection in mind. Miter boxes are notoriously bad for tossing dust everywhere. Bandsaws also produce a lot of dust, and most are not designed to contain the debris.
You really will want some sort of dust separation (two stage). Either a cyclone, or some sort of baffle.
With dust collection, you are looking for massive CFM. Which you will get with big impellers. Which will need big horsepower motors. Think 3hp or more. If you're running multiple machines, you'll want this for certain.
Most 2hp or under systems are 120v. If you want to go big, then you are going to need 240v. If that isn't a problem, I'd definitely go 240v for the larger setup.
Are you going to look into hard plumbing the unit? Or running it on flex hose one machine at a time?
My dust collection is a HF unit I picked up off Craig's List a few years back. I did all the 'upgrades': Rikon Impeller, Super Dust Deputy, Remote start, and filter:
In the end, I would not recommend going the modification route. Economically, you are better off buying a bigger machine. Look at Grizzly and Laguna for machines under $2000 that suit your requirements.
Enough for now, but a lot more if you want to hear it.
Hack
Thanks for adding to my homework with Mr.Pentz. Grizzly is not an option in Canada but I believe our King is the same except for the name. Our Laguna dealer is limited in product but he is also a King dealer. To tell you the truth Craftex appears to be better than the King in similar $ comparisons.
I was looking at 2&3hp sizes likely will be the 2hp. I have a fairly simple method of running my cabling in tray so 240v will not be a problem.
My dust collector will be portable and on wheels. In the summer I can just roll out my tools to the driveway. Flex hose with a triple head for running more hose to more equipment if necessary. Cut offs for any hoses not being used.
I had looked at the Hepa filter add on but found these were not necessarily a good purchase. I suspect that my money would be better spent on containment systems catching the wood chips and dust and funnelling them into the 4” dust pipe with good CFM.
One guy on GJ showed a containment device either used on a Radial Arm or sliding saw. That would be great if I can find the manufacturer. A good sheet metal guy would be great to know.
By the way you have a nice setup. A nice clean space that is what I’m working toward.
Bill Pentz is the reason I didn't buy a dust collector. By his standard (it's been awhile since I studied this), there are very, very few dust collectors that qualify. And all of them are unGodly expensive.
Dust collection, the health hazards associated with it and the plethora of machines on the market just made my head spin after awhile. I worked unprotected for so many years that I decided starting to address it in my 60's probably isn't the way to go.
5
Lardy.
Maybe I don’t need any of the Pentz homework previously mentioned. I’m in my mid 60s and just getting around to it myself. But finally have the time and space to try it. Most of the time I would be outside doing woodworking not a great idea here in the winter. Years ago I could use the basement but I have slowly built these areas into a living area and had no space to do larger scale work when the winter settled in.
Stumpy nub has some good videos on that topic.
Acer
I will be checking out Stumpy as soon as I finish up this thread. Thanks.
I have the hf version. It gets the chips. All the bag versions seem about the same. For the size of my shop I should have a 5hp Oneida or Clearview cyclone.
Jar
We should see some pics of your shop. Oneida I’ve heard of but will have to check out Clearview. Guessing pretty pricey.
To answer your question on metal type. If you are likely to use it for any floor cleaning and likely to pick up stray nails and screws a steel impeller will lead to sparks. How much of a problem this is in real life is moot. There are stories of all types of incident on the net but if it was a serious issue I'm sure steel impellers would have been banned in small dust collectors.
Not sure what type of filter is on the machines you listed but you really want a pleated filter. My collector which is used with a planer / thicknesser and table saw has a bag filter which will allow the smallest dust particles through which are the most dangerous to health.
Steve.
You are likely right on the liability issues in regards to impellers. Steel impellers would be able to put up with knots flying better than even the die cast aluminium. I’ve read where some of the cheaper units have plastic impellers.
Are you talking a pleated filter in a can with the rotating arm that knocks the dust down. I was looking at a Hepa filter in a can with a rotating arm is this what you mean?
Yes on the pleated filters, the bags seem to do almost nothing against the fine dust.
I also scrapped my idea of using old metal hvac ducting after watching stumpy nub.[/QUOTE
Acer
So what are you going to use plastic flex pipe?
It really depends on what you are connecting, and how much you care about dust where you are working,
I have a planer, and it’s the main reason for the dust collector, a missed chip will mar the finish. I will connect it to the TS and Band saw when I use them, but it doesn’t grab the same percentage of volume. I really need a cyclone for the planer.
I have a Jet DC 1500, with bags top and bottom. When it kicks on, it tosses a bunch of dust in the air. Fortunately for me, I do all my volume work in the driveway, so I don’t care.
If I was working inside, I would want the best filters I could get.
Most of my fine work is with hand tools, so I don’t sweat the wood shavings from the planes, though a DC would keep them off the ceiling.
The dust is a concern, I’m not able to work outside year around. I have a 12” Hitachi Planner/Jointer. Are you saying the Jet can not keep up with the chips and the shavings are backing up?
Are you suggesting the Hepa filter. The machine I’m looking at does a standard 1 micron and the Hepa takes it to .5 micron. The cost to get the extra half micron is approx $500 extra and the appear to be on back order.
I installed my set up out of the shop area in a separate add on room so it is quieter in the shop area. Ran 4” tube to RAS and fittings for other saws and equipment.
Thought of this after my other post...maybe look into these too...nice for extra cleaning of airborne dust of the fine type.
Tarmy
I do have a power/utility room but it is getting pretty packed up. My other room would be simply being outside. Not a great idea in the winter. Thought I would keep the dc portable and then I can shove it where I need it. It likely will just be centred in the shop for ease of access and power connections.
I do like the ceiling mount filter. I’ve noticed them while looking for dust collectors but never really thought about it till you mentioned it. Thanks
Lot of variables to consider. Are you going to run ductwork or do you prefer a portable type machine that will only be connected to one machine at a time. CFM is important - primarily with a planer because if all the chips aren't removed, they can sometimes be pressed into the wood by the rollers. Do you even need filters? Some systems just vent to the outside - but then you need to consider if your heating or cooling your shop, you need to take the loss into consideration
Start with what machines you have and what the cfm requirement is for each machine. Here is an example:
Git
Portable at least for the time being. I can see at least 2 machines on it at a time. I generally have my table saw and Sliding unit being used simultaneously.
The worst offender I have on your list is a 12” planner. When I use this it pretty well is all I’m using at the time. If I had someone working with me I would make sure my bags are empty and watch my tool CFM consumption.
Appreciate the example for tool CFM consumption.
In the winter my heat is too precious to exhaust to the outdoors. So the filtration is necessary.
Thanks everyone know I will watch some of these Stumpy/Pentz videos.
