Wood Filler?
lbperry
North AL
I'm looking for a non-shrinking wood filler that'll take paint (not stain).
It's been so long since I've done any woodworking that they don't even seem to make the stuff I used to use. But they do make a wide array of wood fillers from a lot of manufacturers. Could you guys recommend one that won't shrink or pop our and is paintable. I'll be using it to repair defects and countersinks in CDX plylwood.
Thanks,
Hawk
Kannapolis, NC
If you are going to paint, I normally just mix sawdust and glue to make a paste and use this.
rlitman
Long Island
Non-shrink limits you to polyester products like Bondo, or epoxy products like JB-Weld. I prefer the latter.
jimreed2160
Tallahassee FL
I used the normal "wood filler" on a vanity that I wanted to paint. The vanity had sawkerfs in the plywood to make it look like shiplap. I scored the lines with a nail before filling. The filler went on well and sanded down fine. I scuffed the surface and painted.
OK. Three or four months later, the kerfs started telegraphing through the paint. Apparently the filler continued to shrink. Next time I will use drywall spackle.
Zeke
3M makes a yellow bondo sold with red catalyst. When mixed it's the color of pine or oak. Many millworks repair new work with standard bondo and if stain grade they will use the yellow stuff.
I make my own out of the gray stuff with yellow pigment. I can't see using any spackle or drywall products. I recently found the old wood filler that smells like toluene. It works well but I still prefer the yellow or standard bondo (auto body filler sold under many names).
L
lbperry
North AL
Thanks for all the replies. Think I've got enough info now to get what I need.
Appreciate the input.
Thanks,
Cyberbear
California
Bondo body filler works great on paint grade plywood, but mix it a little hot so it sets up w/o being sticky.
