So your triple wall goes from the top of the box, all the way up to the vent cap? And also, I've seen these pipe boots that are very cheap, and are supposed to seal the roof up very well, what did you use to seal up your roof? Thanks for the info and pics!
I hope that's not what he means. That is a waste of heat and money if so.![]()
So how much insulated pipe do you think I would need? Just a couple feet where it goes through the boot?
I bought a metal roof flashing with the malleable base from Mueller's steel buildings and used a generic metal cover over that.
Have any pics of the roof side? That sounds about like what I'm thinking of doing.
Any reason you have to go out the roof? Could you go out the side up by the eave or top of the wall? Roof penetrations on metal buildings scare me. Especially if you have vinyl backed insulation under the roof metal. If it leaks, you may never know it because it will just run down the vinyl til it gets to the fascia and rot it out. If no insulation, you would catch a leak.
I thought about through the wall, but for one, I don't want the all the 90 degree bends in the pipe, for 2, I don't want 20 feet of pipe on the side of my building, and for 3, it seems like that's a lot of wasted heat! I don't have any insulation, so any leaks would be found pretty quick.
Also, I don't have a ceiling in the building either, so I could probably just make some kind of support for the insulated pipe. So I would probably need about 3 sections of the insulated pipe! Jesus, there is just no good way to do this cheap is there? Lol
Yeah, I guess I could go up and then exit, but my stove has a rear exit for pipe, so I'd be looking a 3 90 elbows, just seems like a lot bends, and a pain to clean!
That's good as the snow is starting to fly.
One thing you may also want to do is add a general location to your profile. When you ask questions like this, it helps other members answer your questions properly.
20 years on the truck, every fire we went to, the owner was totally surprised when their woodstove caught the building on fire. Every one had a wood stove that was not installed as per code. Most were caused by lack of clearance. But, hey it is your house, so you get to burn it down if you want.
