jimreed2160
Making trim
So when we left our sewing box project, it had some missing trim. I decided to start with the drawers because that trim was pretty simple. It is a quarter round but what size?
To answer that, we need a radius gauge. Here is my set.
As you can see, it is filled with different sized gauges for arcs and radii. I start with the small ones and quickly get a hit.
It was hard to photograph with only two hands but the gauge that fit the best was the 1/4" radius. As luck would have it, I happen to have a few lengths of 1/4" walnut dowels on hand. If not, it is not a big deal because I have a #77 dowel maker. No need to get that out today unless I blow through all of my stock (which could easily happen).
The dowel is only 1/4" and cutting it on the tablesaw would be scarey unless I glued it to a piece of stock. Being a handplane guy, I decided to plane it into submission. Here is the contraption I used.
It is a scrap of wood with a 5/16 groove in it. I cut it to length and put two scraps on the ends to hold it steady. The dowel is flush with the top of the groove. All I have to do is plane half of it off. Well, that is exactly what I did. I stopped after several strokes and checked. I was able to correct my trimming and make it even. It did not take long to make a dowel half.
Now the task is to cut that piece in half. I need to wedge it into the remaining groove. So it is back to the scrap pile. I found a suitable scrap but it needed to be planed. As luck would have it, I have an open workbench to do that operation. The shop is getting a workout today. Then I cut the scrap to length and wedged the dowel half in the groove.
At this point, I could have ripped the wedge down, but I was so tickled that it fit that I just planed it even. It only took a few minutes and I was off to the races.
Done.
Trial fit looks great.
So that is how you take a 1/4 dowel and turn it into a quarter round.
This was easier than I thought. Hope the other trim is just as kind. Stay tuned.
Done.
