Blue--Great job on the crib. Thanks for the progress shots.
I had a good time in the shop today and made progress on the moulding. Here is where we left it.
As you can see, it is taking shape. The plane is tuned up well when it takes a long shaving.
But I was not too happy with the shape so I got out the #4. It has a tighter radius.
Here is the first trip down the board. Whee!
Here is the aftermath of many trips. Notice the nice long shavings.
Here is a close up.
And here is the profile sketch reference.
I am pleased with how it looks and now want to work on some other spots. For the top (which is really the bottom) I decided the #62 low angle jack would be the best plane to use.
Progress shot. The dirty nasty outer layer gives away to some nice walnut.
Another close up.
I needed another reference groove on the end and the #45 was glad to do it. The wide rabbet on the finished moulding is the bottom. I will make it before I cut the moulding off. Now that I have two grooves for reference, gnawing out the middle should be pretty easy.
Now it is time to flip the board and plane the top of the moulding. The board is pretty rough.
But the #62 finished it up easily. Look at the wide shavings.
"Mr. DeMille, I am ready for my close up." (With apologies to Gloria Swanson).
Then I turned the board on its edge for the last cut. I need to put a roundover or bullnose on the edge. It seems like the #6 hollow is just right. You can see how the bottom matches the profile template.
I took a few swipes and was rewarded with nice long strings.
So the moulding is coming along. Tomorrow is full of medical appointments for the queen and shop time will be at a premium.
Thanks for sticking with me so far. This work is not easy and I have been sweating. It sure makes nap time more interesting. As I said before, taking time really adds quality to the finished product. This is not something that likes to be rushed.
Once this project is finished, I will try to gin up a shavings tutorial. The handplane process is complicated because it is indirect. The finished product reveals itself over time. But the question of the craftsman is "How am I doing?" To me, the best indicator of quality and progress is shavings. When a plane pulls long wispy shavings things are usually going pretty well. Wide shavings are also a good indicator. Anomalies in the wood can sometimes prevent long and wide. But when they are present, they are good indicators.
A long shaving from a H&R plane is an exceptionally good indicator of blade condition. These blades must have proper geometry and must be sharp to produce a long shaving. When you see long strings from your H&R, you know your plane is dialed in.
