Work bench goals
j p smith
Glendale, Arizona
So I started out to replace my bench I have had for 18 years. I thought about trying to see how many ideas I could borrow from the forum and still make it work with what I already had. This where I started this morning and how far I got today. I still have one more feature to add. I would like to add a steel storage area between the boxes and the wall.
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
J P Smith I have no doubt that when it comes to ideas for a workbench build the GJ is a one stop shop.:thumbup:
Your old bench doesn't look that bad.
That's a pretty good days work to get it thus far.:thumbup:
What are your plans for the top?
Regards
J
j p smith
Glendale, Arizona
Lookin good JP! Shoulda called me, I would have gladly taken your old bench. Just to help you de-clutter a bit. Haha
Thanks, It went to a friend of mine that has just moved into a house with a 3 car garage in East Buckeye. I kept the bowling alley wood top.
J
j p smith
Glendale, Arizona
Regards
Thanks Half. After seeing some of the really great bench creations here I got to thinking if I could incorporate my boxes into a bench that would gain me some floor space and I had a friend that has always like the bench & cabinets. He made me an offer I liked and I kept the bowling alley wood top. will put up a picture of the top after I set it on the frame. JP
J
j p smith
Glendale, Arizona
Made some headway today on the bench project.
Crazyjake8493
Upstate NY
Love the bar stools! I've got a mismatched set myself, picked up from different yard sales and such. Each one has their own story.
J
j p smith
Glendale, Arizona
I hear you! I have 2 that were dropped off by friends that are my favorites.
Side note, no one has admitted dropping them off. I still don't know who to thank.
Spareparts
Lansing Ks.
I really like the idea of storing the steel, like you said you came here for some ideas and shared one that others can use. Guess where my steel pile is going to be relocated to. Thanks.
drivesitfar
JP: you've got a very cool shop and i like the idea of steel frame and bowling alley top on it with your snap on cabinets below it. i also use your idea of commercial racking with tools, machines and stuff under them because they don't need a shelf near the base.
how did you attach the bowling alley wood top to your metal frame?
also i see you have a MILLER 250 welder and i'm thinking that might be the one for me to start with. any pros or cons with it and would you buy another one if you needed one or what would you buy? i'm between 211 and 250 models of Miller at this point, but i've got a lot of decking and fencing to build first so still doing research
thanks for sharing your bench ideas
J
j p smith
Glendale, Arizona
Drives thanks for stopping in!
I used 1 1/2" angle to attach the top, 5 24" long pieces, 6 mounting holes in each piece, into the wood. Once you remove the original steel cross pieces under the top it gets sort of flimsy. The bowling alley lane is just pieces nailed together.
I like my Miller! Would buy it again. We have a Lincoln where I work and I have used a Hobart at another job. I would get the Hobart over the Lincoln. Although the Lincoln at work has been used and abused by others, might not be fair for me to say I don't like it. In picking a welder I would consider your needs, how thick of material you might need to weld. I think the 250 is great for my needs from thick to thin.
blindley
North Carolina
JP: One of your first pictures shows the top of your post vise on a red stand. Can you show us a picture of the whole vise and stand? I'm sure if you built the stand it's as nice as your workbench.
crab
I like the design of your bench, only thing I would do different is the top. A steel top 1/4 inch or thicker is a must for me but I also use my bench as a welding table.
J
j p smith
Glendale, Arizona
Thanks Blindley. I think I actually stole the idea from GJ
J
j p smith
Glendale, Arizona
Thanks crab.
In the very first picture you can see my layout/welding table. This bench will be for tinker work and hit & miss engine assembly.
I hope to mount the top to the frame later today.
blindley
North Carolina
Thanks for the pictures of the post vise--really nice. The bonus was the rolling stand for the arbor press next to it. Nice job on both.
drivesitfar
JP: your new bench looks AWESOME. WELL DONE SIR!!
it will look even better with your boxes in place and your stuff on top. nice wiring job and is the 220 plug for your Miller 250 welder?
Some day I'll have a big shop of my own, but in the meantime just finishing my house and ORGANIZING my little one.
HAPPY FATHER'S DAY
J
j p smith
Glendale, Arizona
HAPPY FATHER'S DAY
Thanks Drives! Yes the plug will work for either the MIG or the TIG and also the lathe. I did not plan to do welding on this side of the shop when I did the wiring, big mistake one more plug was all I needed
ETwagon
Arizona
JP: also i see you have a MILLER 250 i'm between 211 and 250 models of Miller at this point, but i've got a lot of decking and fencing to build first so still doing research
drivesitfar, check out the Hobart Ironman230. Great bang for the buck. I upgraded from a Miller 210 and I'm really happy with it.
J
j p smith
Glendale, Arizona
All I can say j p smith is your bench is simply awesome.:thumbup::thumbup::thumbup:
Regards
Mucho Thanks Half.
I need to change out the 220 plug, it seems I overlooked the orientation of the receptacle, the plug & cord will not clear the bottom of the top without a very tight turn in the cord.
Next up is to start cleaning up the boxes. I have one box that will need a new set of slides and they should be in this week from my Snap On guy
drivesitfar
JP: i hate when that happens to a plug or since you were having second thoughts about putting it there in the first place maybe remove and put it in another location while you have it apart. your call and always a pleasure looking in on your progress and shop.
ET: thanks for the good words about your Hobart 230 and i'm probably still a few months from having the space to use it so will keep listening and learning before i actually buy a nice welder.
crab
What's the purpose of the extra bracing on the back legs, the part that looks like a ladder ? Nice work .
J
j p smith
Glendale, Arizona
Hey Drives. Not having second thoughts about the location, I will up pick a box and 220 receptacle I can put in the box so the cord will hang down when plugged in
drivesitfar
JP: great idea about using the dead space behind the tool boxes for those hard to store long pieces of steel. :bowdown:
I wasn't trying to talk you out of leaving that 220 plug on the side of the new work bench and thought it looked great there in the first place.
J
j p smith
Glendale, Arizona
Another stolen idea from GJ
No worries. Thanks
