jonnythunder
I've been wanting to build one of these for quite some time. I have seen similar setups around, but this is my version.
I just picked up a small 36" metal brake of of C.L. I always have a need for the tool, but don't really want it out on my bench all of the time.
Here is the picture story of how it went.
Marked out the spot for the tubing to fit in, and drilled some holes.
[/IMG]
Then I used my jigsaw to connect the dots.
Test fitting the steel square tubing.
Adding a tab to the "reciever" to secure it under the top.
Mounting it under the table.
Test fit the "hitch" in the receiver.
Also drilled a hole all the way through and welded a nut on the back.
Starting to fab up the mount for the new brake.
Completed!!
Easy and quick to remove and change tools. I will be making a mount for my vise and bead roller tomorrow!
Hope you liked it!
Jon
Completed!!
Hope you liked it!
Jon
