Looking good
I like the gauges you have chosen.
Keen to see what the bed will look like. Can you tell us more about that front end now ?
The front end is a widened L300. (62mm over standard)
I thought it was 50mm (2") wider when I bought it, and the extra width has meant a brake change on the rear to widen the track a bit to stay legal.
No big deal (I hope) I have some later ones already.
It's fitted with a Leyland p76 rack (or should that be P38, cause they where only half the car they where meant to be
They are front steer which usually get changed to rear for correct ackerman & easier set up, but the akerman is near spot on in the long wheel base.
(wheel base is 3760mm.......148" for you others
It came out of an early F100 as is (same width chassis as the one I have) but I will be changing it to power steer.
For those who don't know. an L300 is a Mitsy 2wd van.(they also come in 4wd)
I chose this front end as it is the only 'rated' one at 2 tonne, 1 tonne carying capacity.
I did want to go all F100, but that would put me into the commercial class as would have the duallies I wanted to run on the rear.
As everything is on the heavy duty side with this build, but not commercial (other wise it would be treated as such & the whole thing would have to be engineered) I figured it was the one to use, especially after I found this one cheap
I have done a little home work on setting up the brakes.
I wil be running Ford Territory front rotors (322mm & almost the same offest as Ford) with Falcon BA calipers (they are 2 spot with wider pads than AU2) and I will have the hubs machined to suit the L300 bearings (L300 stubs are thicker than Ford & there fore have larger bearings and seals) but it will be in Ford stud pattern to take the rotors.
I will custom make some calipers brakets.
The paper work is now done & I will be submitting it on Wed. so here's hoping it will be accpeted as is.
What is the F1 ??? Is that for a customer or another project ?
The '48 F1 is a customers project.
