Workbench build using H.F. 44 inch tool boxes
Krang
Hawaii
Tagging along. This is the first thing I plan on doing when I have my shop finished up, probably a few months from now.
I'm going with Gladiator chests since I got a killer deal on them and a bunch of cabinets. I plan on something very similar to what the OP is doing. I'll remove the center chest to have some leg room and I'll have two upright cabinets bookending the bench. So very similar.
Keep us posted.
-Clint
Same deal here, stand-up height workbench w/ galdiator cabs
Robert Haas
Golly Lucky, I am kinda kno0wn for overbuilding but those gussets and leveling hardware you have make my stuff look like Lego
L
Lucky13driver
Corpus Christi Texas
Thanks Robert. I'm planning a heavy top. I've been eyeing a chunk of 7/8" plate 12 feet by 30 inches at a buddy's construction project I just have to wait till it's available. The price is right through he want a case of beer for it.
L
Lucky13driver
Had a great day in the shop today. I got the leveling feet welded in. Sanded prepped and primered. I may start the frame work for the boxes tomorrow.
ScottsGT
Lake Wateree, SC
Scottsgt thanks I'd like to see your build. I'm really enjoying this project.
Any more progress? I started mine last night. Already painting myself into a corner as far as building the frame and then lifting the box out of it. It's kind of comical what I did last night not thinking clearly. I'm a one man band with a bad back. Already tweaked it unloading the box off the trailer. When I really make progress, I'll make a clean thread on my build. Probably going to get it completed before I post so it doesn't get lost in the wash.
L
Lucky13driver
Hi ScottsGT, Today was my first day back in the shop. Had the Holliday's and a bout with the flu. Today I welded up the tie plates for the bottom supports. Also I cut the corbels to help support the load. You'll see in the picture my new Christmas present a Swag off-road bandsaw table. If you don't have one I highly recommend it.
LXCam
Looking good 13. I was wondering how much luck you had maintaining square with that corner jig. I bought one a couple decades ago but it's such a battle getting it aligned dead on I stopped using it years ago.
L
Lucky13driver
LXCam I had good luck on 3 of the 4 uprights. One of them I had to pull together with ratchet straps. I'd like to get a dry cut chop saw l think the cuts would fit up better.
L
Lucky13driver
Had a busy day in the shop today. I was a welding and grinding fool. I have the framework all done, so tomorrow it will receive 2-3 coats of HF bed liner after I clean up the tool bomb that went off.
L
Lucky13driver
Well today I was able to move the framework into place. Wow that thing is heavy I'm using 3/16" wall material but I was able to move it by myself. Then i sprayed primer followed by several coats of bed liner.
L
Lucky13driver
Today's work has me very close to the finish line. I put the tool boxes in the framework. To lift them I used an engine hoist with the goose neck mounted backwards so it wouldn't hit the lower support rails.also I then ground a flat spot on some fender washers so it would line up with the existing holes on the box so I could mount the eye bolts to hook up the chain. The final step will be to mount the top. This may take some time before the steel is available so I'll probably put a sheet of OSB on it as a temporary work surface.
squigs
You guys with the welding skills are impressive! I stuck with wood for mine, but similar purpose. 2 HF boxes from Black Friday and 3 sheets of plywood from Menard's produced this nice little upgrade in the corner of my garage that was a disorganized mess before.
Sent from my Pixel 3 using Tapatalk
Fisherguy
150 Mile House BC
Thant looks great!
I'm equally ****** with both metal and wood! :bounce:
L
Lucky13driver
Thanks Nutts. It worked surprisingly well. I had Mrs Lucky standing on the back to counter balance the weight.....but I'd never say I used my wife as ballist to her face that would change me to Not so lucky 13.:lol_hitti
cos
Hello I would like add how important it is to have a toe kick when building cabinet frames. Even on frame standards front legs. Also sheet metal flashing to seal off toe kick.
schaumi
Baltimore, MD
What size tubing are you using? Curious to know the ID and the tubing you plan on using for the "receiver" mounts.
Cool project! I like that bandsaw table too - need to look into that.
L
Lucky13driver
Schaumi thanks, I used 21/2" O.D. X 3/16" wall tubing the I.D. Is 21/8" a truck receiver fits in perfectly. I haven't started on the different tool mounts yet but I plan to soon. Currently I'm focusing on getting the steel plate,for the top. I'm using a 4' counter top from some oak cabinets I'll be installing later for a wood working area.
Dodge
Illinois
I just finished building in my 44" HF tool chest. I think it is a very well built and quality tool chest. The top is repurposed bowling alley. Heavy!! The length is 77". I built the frame using 2x4 joined with a Kreg. Behind the door is slide out plastic bins for misc. nails, screws, etc. My son wrapped the fridge with carbon fiber vinyl. Looks sharp. Laptop above the fridge.
Dodge
Illinois
Thanks for the compliment. The brown door on the fridge would not look very good with the black box! Carbon fiber is neat on anything. Here is a picture of the workbench I had in same place for 20 years. Consisted of my kids waterbed drawers!! Remember those? Anyway, Thanks.
cderalow
Potomac, MD
Any chance one of you owners of a new 44" box can take some quick drawer measurements?
Depth is supposed to be 19-3/8", but what about widths & heights?
Thanks
L
Lucky13driver
Cderalow the drawer measurements are: 19-9/16"deep; the taller drawers are 4-3/8" high/tall; and the shorter ones are 2-1/2" high/tall. The top drawer is 36-1/2" wide; the medium is 22" wide; and the small are 12" wide. These are the second generation boxes. I hope this information helps.
ScottsGT
Lake Wateree, SC
And FWIW, its very easy to move the big drawers around. I put my deep drawers on the top, shallow on the bottom slots. All the rails line up perfectly.
cderalow
Potomac, MD
cheers.
Anyone know the width/heights on the 26" wide single bank?
I assume 22" drawer width, but the heights are unknown.
wish HF would just list this on their website.:beer:
Edit: can someone confirm the depths?. Something doesn't seem to add up right.
Assuming the drawer dimensions given are inside:
I'll factor 1/2" in for slides/tolerance on sliding to the inside dimensions, and 1/4" top/bottom for sliding space.
Top drawer is 37" wide outside by 4-5/8" tall
Wide drawers are 22-1/2" wide by 2-3/4" tall or 4-5/8" tall
Narrow drawers are 12-1/2" wide by same heights
That leaves 2-1/2" as the side, top and bottom framing and separator between drawers.
adding all the drawer heights and separations I only come up with a 30-1/2" height.
I understand cabinet only dimensions to be 42" x 34.5"
Maybe i should take a trip to HF and settle this for myself.
L
Lucky13driver
A trip to HF is always a good think even if it's for peace of mind. I went ther several times when I was in the planning phase. I just went outside and measured the two bottom drawers they are 5-1/2" tall. My bad they looked the same
Trapps
The Detroit Zoo
Great thread and build Lucky13!
I am in the Dodge and Squigs camp with wood a wood framed setup.
Dodge, love the bowling ally Benchtop. I have been looking for something local-ish for about a year. No joy.
As other have noted, metal working skills are a great solution. I lack the skills :bowdown: and tools so this is the current status of my shop build:
I have the 18" deep 44s. The shallower cabinets allowed me to make 'Tool Trundles' behind them in otherwise unused space. You can see the whole build in the link in my signature.
:beer:
