Greatwhitewing
- Joined
- Nov 20, 2011
- Messages
- 531
I want to fabricate "cabinet like" boxes from single sided 3/4 melamine MDF panels with smooth surface inside. Top and bottom panels about 60x33 and side panels about 36x33. I want to use 1/4 melamine for rear panel again with smooth surface inside. I am probably going to use 1x4 PVC trim boards for a traditional face frame. I need these boxes sealed well at all the internal seams. These will need thorough cleaning with wet cleaning rags often.
Like ideas for how to seal and fasten this project. I need to make about 9 of these boxes.
One idea I had was a good silicone sealer at the joints, let it squeeze out and fillet the internal corners and fasten with screws. Concerned about the pull out of screws into the sides of MDF panels. I am not too concerned with external appearance so pocket screws on the outside of the boxes are acceptable if they hold.
Would I be better off with PL construction adhesive and silicone caulking the seams? The most structural stress these will see is transporting into position where they will be stacked in various configs and fastened together.
Not sure what to do about doors yet but will have to have something like a 1/2 wire mesh for ventilation.
Side question- would I be better off using traditional plywood and applying a durable epoxy or polyurethane finish?
Thanks in advance for your advice
