I believe that both have the grooves on the open end. The difference is how much area of contact exists in off corner engagement. The 2.0 has more contact area than the original.
Best I can tell there’s no difference. I have both mixed in. Here’s a 3/4” Wrightgrip 2.0 next to a 13/16” Wrightgrip “1.0” both have off corner engagement on the box end and anti slip flutes on the open. Length and beam thickness on the same sizes is unchanged. Offset angles are all over the place since they’re Wright wrenches lol. Original Wrightgrips don’t scare me off. They’re all the same. Now pre-Wrightgrip wrenches are different. I’ve ended up with a couple in big sizes and they’re beastly!
How do the offsets compare with spanners in the same series, i.e. 2.0 vs 2.0?
The serrated edges are more pronounced and deeper on the 2.0 wrenches.
Pretty sure it's the opposite. I thought they reduced the profile to prevent the wrenches from aggressively digging into fasteners.
Edit- 2.0 in front. Less pronounced teeth.
The longer pattern on the SO seem a bit "handier" maybe?
And they can also get in the way too much because they are too long.....
There was a hint on Wright's instagram page that a long pattern might be available in the near future.
I would think they would certainly sell a decent amount of long pattern wrenches...
I went on their website, and followed the link to Instagram. All I saw was a longish wrench falling into bin. IDK if that means there's actual long patterns.
I'd likely buy a metric set for alignments though.
Sorry, there was a comment on one of their posts by Wright, I'll try and find it.
The comment is on this picture - read from it what you will.
https://www.instagram.com/p/B7Wv4H6AcIp/?utm_source=ig_web_copy_link
