Wtf ?
bullnerd
Jersey
I received a reply from Elk , he doesn’t think it’s there’s ?
Do you have any other info?
Where did you get it?
Relative?
Yard sale?
I did a quick image search, here's the reply,
"Best guess for this image: ruler"
LOL!
ckucia
West Virginia
Could it be some sort of rudder handle for a small boat?
I'm thinking the rudder would be drilled and stuck on the spike then retained with the little l-bracket.
ard
Any better pictures of the long pointy part and how it is attached to the flangey part??
Also, it looks like that flange is held to the curved part (which is then in turn threaded) with two clevis pins with fixedcotter pins....kinda odd, not rigid, but virtually no real motion.
Hmmm
starquestMM
JC, Missouri
Hmm, Its not far off from an early manual windshield wiper. Don't some boilers/furnaces have a mechanism to knock loose the ashes so they can fall out out a door in the bottom.
bullnerd
Jersey
4000 views and no answer...GJ might be stumped?
The tapered section seems like it would have to have a specific use to go through the trouble of casting a taper?
I was thinking of the tapers used for tying knots, but I did a search and didn't see anything even close.
Old Man Roger
Palm Coast Florida
GJ stumped? PPPFFFTTT :lol_hitti Give it time.
rburke65
Canfield, Ohio
My thought is the ELK is a mfg stamp. Don't think that's the makers mark. It would be nice to have better and more photos.
Radix2
the thumb!, MI
The probe end has that drilled angle side that looks like it should be screwed to a corner of some kind.
The probe is attached by two screws? How are the cotter pins used ? Or is it two pins and secured with the cotter pins?
The curved piece ends in the flanged bolt that is meant to clamp something via the screw handle - looks like for easy use and removal ( since it not a regular nut requiring tools)
I like some sort of temporary ground assembly - generator? Linemans truck? Bracket is to be bolted to some rectangular surface, the replaceable probe goes into the ground as the item is set down (hmm seems shakey), then a cable is secured to the flanged stud?
Was it from Colorado? Mining related?
Copymutt
Colorado
Line from "A Christmas Story". Ah Ha it's a clinker!!!
Shake handle A, Swipes clinker remover B. The coal stove/ furnace is missing.
That's my guess and I'm sticking to it. :fingersx:
Jim
Copymutt
Colorado
Notice the witness mark on the rectangular flange. In use this flange slid back and forth.
Jim
Copymutt
Colorado
Ok, I take back my sticking to it answer as brass would melt in a coal fire.:lol_hitti
I am an old fart and it does look familiar.
Jim
Copymutt
Colorado
As a teen I worked in a filter,sail plant. It might function as a spindle to hold the big bobbins of thread that feed the looms?
Jim
bullnerd
Jersey
Could it be that it is not real at all?
Phantom58 made an artist rendering of a non-existent tool just to eff with us?
ckucia
West Virginia
I've been thinking about this thing in the back of my mind.
From the pics, it looks like the handle marked "ELK" is supposed to go on the other side of something from the tapered arm end. Like through a board or something. The round washer would retain it. But there's no bearing so it couldn't have been a very precise mechanism.
I have to think the tapered end was stuck into something like a wood plank and the L-bracket was used to hold it on.
Whatever was rotated on the taper by the handle would have to either not need to be in any particular position, or have it's own method of retaining it in a given position.
Was thinking about what sort of wood or similar could be stuck on the taper. Maybe some sort of a train signal? Paddle of some sort maybe for material flow like in a mine conveyor belt? You wouldn't be able to exert all that much force with that short ELK handle to lift anything heavy.
Seems like it would have been produced in some quantity. Maybe not thousands but probably more than one. I'm guessing railroads or mining or something industrial. Doesn't seem to me to be marine-related, but I could be wrong.
Neat little mystery.
EOC_Jason
Bentonville, AR
Seems to complex for an oar retainer... Brass makes you think marine or electrical...
I still think it's a temporary grounding rod...
Copymutt
Colorado
Never give up!
I may be repurposing this tool.
Attach the right angle flange to the edge of a heavy work table. Drill the appropriate size hole through the table top frame and attach so it stands straight up. You now have a mandrill for sizing rings (think jewelry) or for hand winding wire (think spring). Pic is a similar tool.
Copymutt
Colorado
I suspect if your working w/ gold, silver jewelry ring making you would want a soft mandrill.
Jim
James E
Raleigh, NC
Never give up!
You'd better not have any trip-hazards near that bench. :eyecrazy:
niget2002
Josephine, TX
It's an industrial hole loosener. There's supposed to be a part with a slot mounted between the washer on the handle and the base part. Then the pointy end goes opposite something with a hole in another object. You loosen the handle and you slide the pointy in in and out of the hole until it's the proper size.
When you're done, you tighten the handle down so it doesn't slide on it's own and poke your eye out while putting the next hole to be loosened in place.
bullnerd
Jersey
"putting the next hole to be loosened in place"
That's a brain teaser! lol!
6500! How many members are on here? lol!
engineer2
Chicago burbs
But seriously, some thoughts come to mind...
Being made of bronze or brass limits its applications.
Some kind of control lever for a boiler, steam locomotive, stove damper.
Part of a machine like mining equipment, printing press, loom, farm implement.
