Wtf ?
Copymutt
Colorado
I'm dieing here, they figured out what the upside down mousetrap in a cupboard was for. Dig up the bodies and ask em what's it for?
Jim
PelicanPines
If you could get one or two shots of it in use, that would be a big help.
Thanks
41ratrod
Springfield Mo.
It maybe a fixture that sticks in the ground to hold a light or something or maybe for the internet to keep use gusting
F
FANTM58
Brighton, Co
OK as promised a few more close up pictures .
Also I may have been wrong about it’s material.
On closer inspection it appears to be bronze.
bullnerd
Jersey
WTF is that thing?
So, It looks like the "t" bracket is probably screwed/mounted to the edge of something semi permanently?
And the taper/threaded section is meant to be easily removed with the clevis pin setup?
Are there scratches on the top of the T bracket that indicate it was screwed down?
EOC_Jason
Bentonville, AR
Does it look like there is any noticeable wear in any spots? Any sort of dirt or corrosion or anything?
Seeing as how it's not threaded all the way that rules out clamping small things...
I thought the L bracket was the same piece as the rod, but it looks like the rod is part of the curved piece and the L bracket just has a hole in it.
If it has that handle with the threaded nut end, then it has to be something you would expect to swap out somewhat regularly.
rnixon
Bronze suggests it might be a grounding spike, for a lightning rod. Elk mfg. made such things in the early 1900's
ard
From a 1917 Scientific American:
INVENTORY Shop Service. We do high- grade experimental and model work. Expert assistance in perfecting automobile and other inventions. Light manufacturing Write or visit us. Elk Manufacturing CO , 1926 Broadway, N. Y.
Looks like also advertised in a few other magazines...Everyday Engineering 1920:
http://www.americanradiohistory.com/Archive-Everyday-Engineering/Everyday-Engineering-1920-05.pdf
Everyday Engineering Magazine
Inventors and Experimenters
The Elk Manufacturing Company offers special facilities for the development end manufacture of Inventions and labor saving devices. as well as the construction of special part.~ for nimbi makers anti experimenters.
Write us
»bout your work. You will Tint obligate yourself In any way. ELK MANUFACTURING CO., INC.. 1926 Broadway,
New York City
Copymutt
Colorado
Wow! Not sure that link helps but a great read. Copy the URL and change the date at the end to see more issues. We sure have come a long way in 100 yrs.
Jim
Lassen Forge
I think I figured it out...
Old school tailgate latch lock (like on a buckboard or hay wagon or pre-prohibition era beer truck or ???) ... the gate is held shut by a spike that goes through a ring (or rings) in the tailgate or side of the wagon (or both), the screw thing is to attach a chain (so it doesn't fall off), and the "elk" part is the handle from which to remove the spike. The "L" bracket is to seat against the wood... maybe even screwed in place to keep it in place unless you *really* want that "tailgate" opened.
I've seen other gate latch pins like this... which is why I've been thinking on it for so damned long. It just took a while to put one and one together and not end up with a screen door on a submarine...
It's the only thing I can think of that matches what that looks like. Comments?
ard
you got a picture of an example??
:headscrat
EOC_Jason
Bentonville, AR
I don't think it's a latch lock, it would be cast iron or steel, not bronze...
Only reason for brass/bronze would be ocean, or electrical... or decorative... but it's not the decorative looking, so...
BFBOB
The Wiki link led nowhere
The additional closeups suggest a function of sorts - the "handle" is a sort of wing nut; can't operate the thing, only secure it in place - think of older vises that secured to a bench with a through-bolt and a wing nut of some sort.
I envision the threaded stud going through a vertical wall/partition/gunwale and secured by tightening the threaded "handle". SOMETHING, completely missing now, slipped over the spike and was secured to the L bracket with screws. Pulling the cotter pins would allow the something to be removed easily when not needed. Loosening the "handle" would allow the whole thing to be rotated down to a horizontal position when not needed to be standing up vertical.
That's the function the mechanicals suggest. As to exactly what, I still can't hazard a good guess. Maybe some sort of signaling device? Needed fairly often but not all the time??
Of course, it could be an ether-collecting antenna for recharging the flux capacitors.
bullnerd
Jersey
"The Wiki link led nowhere"
It led to the USS ELK ?
I'm Suggesting maybe its part of it?
Since there are a lot of comments that it is nautical.
bullnerd
Jersey
Yeah...but the ship wasn't named the "Elk" when it was first built.
Not saying it couldn't be part of some kind of retrofit tho....
Picky-picky! LOL!
I didn't even read the article, just saw the ELK name. I know zero about boats!
F
FANTM58
Brighton, Co
Wow , you guys are doing great, ! I did a quick search online then scratched my head
Then posted it here,,, keep going .
BFBOB
It led to the USS ELK ? .
Tried it again just now - it only went to a page saying it couldn't find an article by that name. Maybe not exactly nowhere, but nowhere helpful.
