Xcelite repair.
Mike'smeatshop
This is a 2 ft driver that I would like to put to use some day. I found it in a old carpenters box from the 1950s. He even has his social security number marked on the outside of the box. Sold it years ago. But I think This driver just fell and broke. Is there a way to bond it back together? Thank you. Thank you very much.DSCF6561.JPGDSCF6562.JPG
paulsomlo
Northern Colorado
I don't think there's any solution that will make it whole again AND make it look pretty. Try brushing some acetone on the broken areas and see if you can't do a solvent weld.
Mike'smeatshop
Thanks. That is what I will do. I guess it is more important to have it working than what it looks like.
Zrxrunner
Eastern Iowa
Never tried this on that material, but if you want to add some rigidity, maybe try to drill a pin into each part where it's broken to hold it together when you fasten it? If you do this ,you might have best luck sanding both pieces flat to get it centered. Not sure if it's worth that much hassle to you, but might be best way to make it strong again
Mike'smeatshop
I may try to drill and tap from the end and then with some epoxy. Thanks.
slowtwitch73
Hellgate
Do you have a lathe? I would face both ends and drill n tap, screw it together with some adhesive.. make sure the handle is clocked correctly. Shorter, but good.
Mike'smeatshop
No. Don't have a lathe but buddies do. But I have been looking for ideas like the Plastic weld also. The handle is way to long to start with. I believe that is the reason it broke. Too much leverage on the end. Thanks men
