XMAS house lights made simple
I hate spending (wasting) time hanging my house xmas lights so I've pre-mounted them and I can hang them all in like 15 min.
Here is how. (at the request of someone on the "What did you do in the garage" thread...) Apologies in advance for some of the pics, having exposure issues bad lighting outside today, and the paucity of pics, I made these many many years ago (I'm actually on my third string of lights as SWMBO changes the "look" she wants...)
Pretty simple really:
Materials:
  • 10 or 12 ft 1 X 4's sufficient for the length of the lights you want to hang. Some may need to be cut to length.
  • Primer and paint (so they blend in when installed, and to keep them from warping.
  • Cup hooks for garage storage; 2X as many as you have boards
  • Eye screws to put in the 1 X 4s. get extras...
  • Deck Screws for mounting on the house (at least this is how I did it, you could also use cup hooks on rafter tails) - this is why you need extra eye screws, in case the garage mounting spacing is different than house mounting. I prefer the galvanized screws so they don’t rust.
  • Nail on 1/4" cable clamps. - To attach wires
  • Plastic cable clamps - the type that screw down the smaller ones seem to work best
  • “Grabber” screws ½” long - for the aboce clamps and other things…
  • Lights! – Go for the LED - cheap to run and low maintenance! (does anyone LIKE to chase burned out bulbs? Also, this mounting technique makes the lights
last a LOT longer!
Optional:
  • Hinges in case you need a slightly longer run of mounting board. I have one that is hinged and extends for an added 4 ft.
  • A straight “strap brace” - similar to corner or angle braces but straight and with 4 holes – this is to “splint” the hinge joint when extended.
After painting the boards and while waiting for them to dry, FIRST put up cup hooks on a couple of likely garage rafters for storage:
This determines the spacing of the eye screws on the boards; if you have fascia boards you can probably use these to hang them on the house.
Make sure this fits before proceeding!
For the house, determine where the power for the light is coming from. I drilled a hole between two rafter tails near my from door. This is sort of central to the completed light string. I’ve run an extension cord through this with enough slack to allow me to pull it out and connect at the rafter.
The other end extends to an outlet that is near my house to garage man door, I use a timer here so they go on and off automatically.
Start at the power and go from there. Hang the boards from the house FIRST! Mark them! Number, (R/L for direction), name place, SOMETHING! You need to be able to get them back out in the right order… (Mine are marked things like Garage Entry, Garage Right (and Left) etc…) I marked them on the top edge so it doesn’t show.
I have Icicle lights, so I use the nail on ¼” cable clamps to attach the light string. You could also use the screw dwon type for this. The light strings WON’T be the exact length for each board; don’t sweat it!
On the next board, (space them the distance they will be on the house) you will (probably) either fall short, or be too long on the light string wire, and you have to take the light spacing into consideration.
Leave the hanging string end loose, and attach some of the plastic cable clamps, but leave the clamp open! (See Pic) Screw on the bottom of the clamp and leave the second top loop loose. This allows you to snap a cable in place on the fly.
Once you have the spacing right, this should also keeps the wire taught and the spacing right. Start the next line and use the nail on clamps as much as possible.
I often add a couple of the “on the fly” cable clamps high on the board where the strings couple so I can pull the connecting plugs up out of sight.
Continue until you have all the requisite lengths done. You are ready to hang the lights!
For a gable, (my garage is gabled), I can connect two boards and my son and I lift the ends together and walk to each other so we end under the gable peak. The deck screws, are an hard target, but we get them both hung from the peak all without needing a ladder! This is one place we needed extra eye screws, as the gable boards needed an eye bolt near the very end…
Then we walk each end over to the side and use either a 4 ft “safety” ladder set my mother bought all of us “kids” many years ago, or a 3 ft step ladder to hang the lower ends on another deck screw. Done with that part! One end has some extra light string and I have the “open” cable clamps mounted permanently on the house for this. Snap, snap, snap, and that end is done.
The other end has to get the extra string off the entry run board snapped under the open clamps for the purpose, and that is done. That is about ½ all my lights! The rest are a straight run to complete.
Pics of them lit later tonight…
I bought some GE Icicle Lights a couple of years ago and they came with this style clip
GE Universal Gutter Clip
They can clip over a gutter or slide under a shingle. Just leave them on the wire and next year they go up quickly.
Falcon67
Merkel, TX
I ran 1x2 sticks (used to do wood, not using PVC) under the edge of the facia where I put lights. I only use C9 12" spacing under the eves. Using 5/16" staples, I just bang up the lights with a staple at every socket. When it's time to take them down, grab one end and pull - they pop right off the 1x2.
LS6 Tommy
Northern NJ
I put brass cup hooks spaced 1' apart, just under the gutters. I can get my icycle lights AND C9s up in under an hour...
Tommy
CSRPenFab
Meridian Idaho
I use those on the front of my house where the gutters are, but I have some that thread onto a long extension pole. You clip the lights in, and then raise the clip up using the pole to snap it on the gutter. For the parts of the house where there are no gutters, I have similar clips that grab onto the thickness of the facia board, again using a pole. Clip it on and unthread the pole, move on to next clip. I can put up the entire house in under an hour and never leave the ground! Taking down the lights is just as easy, thread pole in and unclip!
O
I tried for a few better pics last night, an finally got them processed...
Still fighting lighting (or lack of same) in the last 2, but...
The Extension cord. it used to start exactly at the corner, it moved a few feet when I switched to LED strings.
That lower gable. These two corners and the "Power corner" adn twice at the long low run were where I needed a ladder, but its a very short ladder, intended for indoor use, generally. more like a portable set of 4 steps than a conventional ladder. That's all that was needed
The long run as seen from the front steps:
The boards onto the Peak was (after the deck screws were put in initially >25 years ago) were done from the ground, 2 boards simultaneously, (as they have to get plugged into each other...)
And 2 shots from the front, with and without flash... but you get the idea of the amount of lights. All this went up in 10-15 min. (Those "gaps" are caused by my front yard trees and the branches - None of the LEDS are out. 3rd year of use.)
O
Tommy
LS6,. I used to have rope lights on the lower edge of the boards, but we finally discarded those. If we do it again we will use LED Lit C9's and probably colored as SWMBO is getting bored with white..
I'd considered doing C9s on hinged boards, when I did this originally so all you would have to do is swing them up under the gutter/eaves, and latch them. If white, that could be used for "accent lighting" out of season... :dunno:
JCQuick
Apopka Fla.
The tea cup hooks is what was on my late mothers house it did make it real simple.
At my house I use a plastic "S" type hook that slips under soffiting . I also store mine in a plastic bin separated by what section of the house they go on.
thewatusi
Philly Burbs
Cutting, priming, painting, labeling, and installing lights on a bunch of 1x -- and then trying to store them and hang them - in the right order on a bunch of hooks all without getting any wires tangled is "making things simple"?!?
Boy, you've gone full retard.
O
The wires are permanently mounted to the boards, so I've NEVER had a tangle in over 25 years of use, and that is with icicle lights... Can you say that with coils of the strings?
5 boards up, 5 down, and they hang in the garage out of the way in 5 min...
Did you even bother to read what I wrote? :dunno:
ripperd
Twin Cities, MN
Do you have a better solution to xmas lights (besides none at all)?
O
Probably not; from the posts I just skimmed of his, he appears to spend most of his time making caustic remarks and moving on to the next thread before he can be accused of trolling...
thewatusi
Philly Burbs
Yes, these:
I coil the lights up before storage and don't have tangles. The several hundred feet of holiday lights that I have fits in 2 18gal totes. Takes about an hour each to put them up or take them down.
Those laser light things are cool - but a little pricey.
O
So 2 hours each xmas season. I take 30 min total.
Do the math; after 25 years (more...) I've saved almost 40 hours, for an investment of maybe 4 hours.
I also don't have to store 2 totes. The space these take in my garage is not useable for any other storage, so less wasted space.
But I'm a retard...
mdbeck1
Norman, OK
