Xtream Set 100?
Mmattia
I'm sure Scott will have the answer but I was wondering what if anything I should do before using the crack filler in a shallow gap between two slabs in my garage. There is no saw cut just a shallow gap maybe 1/8 to 1/4", I had an issue with the first couple if feet of my garage that had a bunch of cracks. The builder saw cut out about 4 feet and just re-poured right up to the existing slab. Should I use a diamond saw and open the grooves up or just lay the Xtream Set. I just want to make sure it holds, don't need it lifting after I finish the epoxy.
Thanks for the groups support...d573723dc1b6393aa46da1d64a50a404.jpg5fbdb9d96c44c2f9e9539559353c1e4a.jpg
Sent from my SM-G955U using Tapatalk
stm317
Legacy can chime in with actual help, but I'd just fill it with play sand, level it off, and apply the Xtreme Set. Mix it in small quantities. I was only able to get a few feet at a time before it would start to set up in the bottle.
LegacyIndustrial
deerfield, IL
Well done! Once you get the hang of it, you can treat longer lengths of crack/joint faster.
