ratpowered
I've been lurking for sometime now and have learned much.-Thanks
I just purchased my retirement home that included a 2000 sq ft shop with a mancave (apartment/dog house) above it. The previous owner divided it into three bays. The two outside bays he used to store his travel trailer and boat so they were unfinished. They are 17' x 40' with 14' ceilings. The center bay has the apartment above it. It was used for wood working so it is heated/air conditioned and totally finished. It uses the furnace for the apartment. It has all 4 walls sheetrocked and insulated with lots of lights and cabinets and benches- very nice. I build hot rods , so the shop is changing. I've insulated (R38 in the ceilings and R-15 in the walls)and put 16 4' lights per bay on the ceilings. I've bought 2 75000 btu natural gas Mr Heater heaters from Northern Tool- 1 for each bay because they are separated by the shop in the center which I use to build engines, so I want it keep clean and seperated from the other bays which we use to do metal fab and welding. Now for the questions. I've read all the posts on here about the heater installations, but still have several questions:
1. I've read that the heater work best if they are closer to the floor(approx. 8'). Do I need to drop them down from the 14' ceilings or will they work ok @ 14' ? I know they are a bit of overkill but the price difference was minimal and I plan to let the temp drop down to around 40 when we are not out there working and want to bring the temp up fairly quickly. I now live in Utah and it does get cold here in the winter!
2. I didn't purchase the vent kits for installation. What does the Northern Tool installation kit include? Will I have to purchase additional pipe for the vertical exhaust or does the kit included all the pipe and elbows etc that I will need? Can I go to any HVAC shop and purchase what I need for the same price or is the Northern Tool $110 price a good deal?
3. I want a thermostat, but the one that Northern Tool sells has a lower temp setting of 50 degrees. I want it to drop down to 40 while I'm not there. I've read all the discussion about cost/savings and temp settings- I'm an engineer (mechanical not HVAC) and have my own theories so I want the thermostat to let the temp drop to 40. Can I install any thermostat or do you have to buy the Mr Heater theromstat?
Thanks for the help,
Dennis
Dennis
