DGersic
Anyhoo, I've said it before and I'll say it again: I want a selectable load tester for 12VDC work.
I envision a box with a knob on the front, two wires sticking out (or banana plugs), and a window with an incandescent 12V light bulb inside.
I want to turn the knob to select different amounts of load; say, 1/2amp, 1 amp, 2.5 amps, 5 amps, and 10 amps.
A voltage readout, perhaps, if we want to be fancy. I'd also like some sort of audio feedback, in case I can't watch the magic box from where I'm working. Maybe a squeaker that squeaks louder the more current it's seeing.
The simple version of this seems like you could use a few high watt cement resistors. There‘s your load. Add a rotary select knob, there’s your 1/2.5/5 amp load selector. Get fancy, add volt and amp meters, but you probably don’t really need those since it’s a 12V circuit, and you selected the load already. Couple of banana plugs for the leads.
I can’t think of an easy way to do auditory feedback on this.
I can’t see a market for selling enough of these to be a viable product. But a few bucks at Mouser would get you all the parts you need to build one.
