Zach Suhr's New/Old Garage Thread
SUHRsc
Harrisburg, PA
I'd like to thank everyone for all that I have learned from this board and all of the advice I've been given.
I enjoy looking at the photos of everyone else's shops, so I figured it is only fair that I contribute some photos of my own.
I had been looking for a house and garage of my own as I have been working from my parents basement and drastically out of space. Earlier last year I was talking with an elderly friend and learned that he was in need of making some big changes and fast. We worked out a deal for me to buy out his property, shop, tools, etc., leaving him use of everything. This man has taught me a lot of what I know about metal shaping and antique race cars. So needless to say, this was a dream come true if I could make it work out.
Through a lot of obsticles we finally got it all worked out on paper and the deal was done in June. Since this time myself along with my dad and a few friends have been working away trying to clean up the property and clean and organize the shop. Also to finally get some of my cars inside of a building instead of under blue tarps as they have been for years.
There are 2 garages on the property along with a ranch house. The larger garage started as a 28'x40' building with a flat roof. In 1982 a 25x50 side was built on along with a peaked roof over the entire building. Inturn creating a loft above the original side. The 2nd garage is a "kit" building from the 1970's that is 24'x30'
Earlier last year before the "green" really grew in, I took this photo... if you can imagine leaves on everything... the place was a jungle!
Another showing some of the vines!
This is a photo from 1982 while building the new section on the larger shop.
And now all cleaned up with the vines removed. Those suckers sure do grab on... the roof had them growing up under the shingles... between the plywood facing on the sides... etc....
This photo is of my dad and I, you can sort of see how full the building was when we started.
After a ton of work we finally got it cleaned out, expansion foam glued to the walls and ready for concrete.
We went with 4.5-5" 4000psi concrete with a plastic vapor barier underneath. Unfortunately I couldn't afford to put the heating in the floor. Though this side of the building will likely just be for storage. You can see along the right side, the different blocks where the other half of the building stops...
In the mean time we cleared away all the vegetation from the small garage also.
Cleaned it out and reorganized with a couple of my vehicles inside.
With the large garage cured we started on the shelving that I wanted to build for storage. This was old pallett racking that was being scrapped at my work. I took the entire pile and pieced together the best 5 sections. Assembled into a deck rather then a row. They are a few inches apart each making the area 10' x 18'7". The stairs were also in the scrap pile, needing only a few rails rewelded and straightened. They are temporary untill I can build a permanent set. They're too steep for comfort coming down forwards.
One level at 7ft high. 2x4's for cross support and 3/4" tung and groove for the decking.
2nd level at 12ft, which will be getting 6ft tall 16ft wide 3ft deep shelving ontop along the center wall of the building.
The other half of the building is still completely full of stuff. Though already a concrete floor, I am planning to repour to the level of the new side as the floor slopes toward the back. This side will be my workshop area in the end.
Thats about it for now. Still a ton of work to do but the cold has set in and money is very tight.
Hope you all enjoy the photos.
Zach
keduner
Parker Colorado
Congratulations Zach. This is going to be very interesting to watch. You (and your dad) have done a ton of work so far and the place is looking great. Do you have any history on the wood frame structure sitting in the blue pickup bed (above)? Please keep up the pictures as you work. Good luck.
SUHRsc
Harrisburg, PA
Thanks guys...
The wooden form on the pick-up bed is a pattern to a Lotus 11 front body section. This being a metal shaping shop, there are a whole bunch of different forms. Mainly 1920's-1960's open wheel oval track related.
Thanks
Zach
408Chevelle
Looks like a fun project! What other plans do you have for it? I just took a look at your website. Did those cars belong to your family?
3cyltrbo
great start so far
looking forward to updates (and some info on the project cars)
W
SUHRsc
Harrisburg, PA
Thanks
A lot more plans... office above the right side with a geothermal heat system for that half of the building (only having returns in the office area to keep smell in the downstairs workshop)
The workshop side, once a new floor is in, will be fully insulated and painted bright inside for a more condusive space to work. The large left side will hopefully be made to appear as though it could have existed 60 years ago...(give or take)
I have been playing with ideas for sprucing the building up on the outside...
This is one idea...
Everything is based entirely on the fact that I am now broke. So its little by little.
I have been paying for a house with my girlfriend, and now this place also untill we can fix it up and sell her place...
Most of the cars on my website are ones that I am currently or have worked on in the past. Unforutnately none of the cars my family built have survived.
I have a strong interest in the period from the 20's-early 50's So most of what all I work in is related to this time frame. I trying to make them as period accurate as possible.
thanks for all the interst
Zach
Vette60
Glen Allen, VA
Great work and cool rides too Zach...have you checked out the restored 1930's Auto Shop thread here? Sora of similar starting points...
Looking forward to seeing more. Keep up the great work!
R.
993James993
Some one needs to start a best of 2011 thread and put this garage there!
It looks great. Please keep the photos coming.
WhatThaFrig
Very nice! Like the use of pallet racking for a storage loft. Yes, I am jealous!
hdv32
Paragould, Arkansas
If this is half as good as the traditional rides you have put together it will be an amazing place. I have been following your builds on the HAMB. Would love to have you put together an AV8 roadster some day. Keep us posted on progress.
Boosted1
Georgetown, KY
Congrats on a fantastic looking place with great potential although it is already nice with the work you have done.
I love that last pic. Nice cars.
Firebrand
New Hampshire
Great start and super future look for the complex. Keep the updates coming! Don't let a little cold and snow slow you down. Great time to rough in electrical and shop air lines, too!
BSAschields
East Coast
Zach - Great space ! nice work too... I love the cars and your interest in them... Not only do we have that in common but I see you are from Harrisburg..... ME TOO. Well the new house is closer to Gettysburg but pretty much in the middle.... Do you know the band the Martini Bros. ? Those guys are into our interests as well. Love to hook up sometime and shoot the S#!t about it all.... Maybe over a beer... I'd like to see your cars a bit closer when you have time... Do you do all the work yourself on the cars? Been to the Jalopy Showdown? Right up your Alley! Wow that was a lot of questions Sorry!
SUHRsc
Harrisburg, PA
Thanks everyone...
sorry for the late reply... been busy busy busy with the weather turning a bit warmer here and there....Also took on a few side jobs to help pay for things....
Actually using the garage without it being done isnt the best idea... but... gotta do what you gotta do!
BSA... I have heard of the Martini Bros. the one guy cuts my girlfriends hair actually...
I do most of the work myself... but my dad helps when I need it... he's been helping a ton on the garages!
Heres a photo from this weekend of the 2 garages... still need a lot of work!
Zach
Flathead Youngin'
Southern Ohio
Son...you got yourself an old Ford tractor too....
Lookin' good buddy.....
ALL of my progress has come to a crawl; garages, hot rods, you name it....need to stop having kids!
Drewfus
Newcastle, Oz-Trail-ya
top stuff, great to see where you've been focusing your enthusiasm of late, has plenty of potential, and will compliment your goals I imagine rather well.
Keep stripping back the overgrowth, keep forging on for as long as you can, with some simple/budget detail of painting the racking and the like will make a rewarding difference.
Cheers,
Drewfus
santagary
Pagosa Springs, Colorado
CONGRATULATIONS ZACH! It's refreshing to see someone your age with a work ethic and the ambition to tackle a project like this. Your dad must be a fantastic guy also. So many young adults these days are running around with their heads looking down into smart phones, texting for hours everyday. Keep us posted with lots of pics.
JC23
Northcoast
Is that an old stock car under the shelving????? With the white booger bar????
Oh man, I'd love to see more of that!
Nice work, Zach. I'll be watching this one!
Scuderia-F1
Stockholm, Sweden
Zach that´s an awesome shop you have bought.
I´m really looking forward to see you develop it in to the "time-machine" of your thoughts.
Needless to say, but those cars you have there is also awesome.
ol55
Glen Arm, Md.
Congratulations Zach, really neat place with a ton of potential. Looks really cool with all the hot rods under one roof. You must be syked!!
TBOS2K
Winfield, IL
Awesome garage! Subscribed!! Not the best with that era of cars, can someone please list the hot rods in the picture? Any more pictures to?
SUHRsc
Harrisburg, PA
Thank you all for the great comments.... I really appreciate it and it inspires me to keep plugging away!
That is an old stock car under the shelving... its a 1934 Ford Driven by Ron Tilley won the 1957 and 1958 track championship at Silver Spring Speedway in Mechanicsburg PA
The other cars are all 1928 Ford Roadsters...
Heres a photo from this week... my girlfriend got me a convex mirror that was being thrown away... so I mounted it on the wall and took a pic into it from the top of the shelving... place is a bit of a mess with working on a side job right now...
JC23
Northcoast
Thanks for posting the old stock car shots. I'm diggin' them as well as your shop!
