ZMotorsports Shop Projects 2.0
jjeffries
I need some educatin', please,
The air system fitting repair: does the bus use compressed air rams to open and close the doors (like a city bus)?
What's the big green metal box/tank that's slid forward from the front of the bus in the picture where you greased the front end?
What do you use to jack up the front end?
Thanks in advance for the lesson. John/CT.
Z
zmotorsports
Northern Utah
John, the compressed air for the door is not to open/close the door but to supply compressed air to an air seal that is encased in the door jamb. Once the door is closed, the air operated E-brake is released and the coach is placed in gear, the solenoid opens which allows regulated compressed air to enter the seal to create a sound proof seal. This provided a very quiet and air leak free seal while traveling down the road. No air whistling or hissing past the door when driving down the road.
The big green box sticking out the front is my Onan onboard generator. Our coach carries a 10k watt Onan Quiet Diesel generator to provide AC power to the coach's house system.
As for raising the coach, I have an air over hydraulic 22/35 ton jack that I use to raise it and then a couple of 22-ton jack stands to place under the coach to secure it in place while working under it.
Hope that answers your questions and if you have any others please don't hesitate to ask.
Thanks for stopping by my thread.
Z
zmotorsports
Northern Utah
I was able to complete my axle fixture tonight.
I like to “blast tack” components so I can simply weld over the top of them on final weld. To do this I bump my amperage up to nearly double what I would be welding at for the specific material thickness. Then just max the pedal and a small fusion tack will form. This is done very fast and works great when TIG welding because it will allow you to hold a component with one hand while holding the TIG torch with the other to tack.
Bungs final welded.
To prevent the tubing from bowing or pulling I place a TIG rod under the middle and clamp each end flat to the table. Basically pre-loading it to compensate for the contraction.
Bungs welded on the two slider pieces.
Next I cut out the two straddle supports and blast tacked them in a couple places to make them symmetrical.
Blended and speed holes added.
Next I clamped the vertical support tubes in the mill vise and found the middle with an edge finder. DRO’s are so awesome.
Cutting a 1/4” slot to a depth of .800”.
Test fit.
Tacked in position.
Final welding completed.
All components completed and ready to bolt together.
Ready for use and another item knocked off the white board.
Thanks for looking.
lilscorpion
Colorado
That’s sweet, I like it as an add-on to the ****** Jack. Thought - add another rail forward of that one and make another U so you can support the pinion. The rail would only need to be half the length too. If I had one I could more easily adjust the uppers on Andrew’s LJ at the moment.
Z
zmotorsports
Northern Utah
Great work Mike!
Another piece of artistry by Craftsman Mike.
Another great project.
I like what your neighbor did with the flag, that is a nice gesture.
Great work as always Mike!
Thanks guys. I appreciate all of the comments.
Thanks Matt. I'll keep that in mind if I end up needing to support the pinion. For the most part I just wanted something to catch the axle and provide a means of getting it over to my fabrication table where I usually do the work on them. Then positioning it back into place without having to raise and lower the vehicle and climb around on my back.
Next up this winter is a different type of fixture that I want to fabricate to hold the axle securely to my fabrication table for not only setting up gears but also when adding or modifying bracketry. Something for using the table as a reference and then set up mounting brackets at certain degrees and dimensions. Still mulling over ideas in my head but I think I have somewhat of a plan. Let's say that the plan is in "jello" as it's not quite rock solid yet.:lol_hitti
All of this is more due to the fact that I no longer have my trusty sidekick in the shop like I have become accustomed to over the past 25+ years. My son's been by my side in the shop since he was about 3 or 4 years old and giving me a helping hand since he was about 5 or 6 and very helpful from the time he was about 8 or so and now I'm back to working alone and having to figure out what that looks like and how to do certain jobs so I'm not calling him every other day to give me a hand. This fixture will definitely help with getting axles in/out of vehicles.
Thanks for following along and commenting everyone.
polexican23
burbs-Illinois
I am stupid and sure the wide caster base helps, but would it be more stable if mounted it across the center of the top plate on instead of across the front of the plate? does that even make sense?
Z
zmotorsports
Northern Utah
Yes, that makes perfect sense. However, there are movable supports that run across the middle which negated the ability to fasten anything in that area. The table does tilt in both axis so my intent was to merely preload it one direction when putting the load of the axle on it. I would have much rather mounted it across the middle but this was the next best option and really the only option to keep the movable supports functioning.
Thanks for the question and I hope the response makes sense as it may not easy to see in the picture(s).
rattle_snake
Chandler, AZ
Nice job (as always) on the axle adapter.
It would be much easier for me, if you lived down the street so I could use all your custom tools instead of having to duplicate them. Maybe even leave a project vehicle in your shop for awhile so you could do most of the work.
I get the one man show, as I get 'older' I can't just muscle heavy stuff around anymore without consequences.
Z
zmotorsports
Northern Utah
Thanks for the comments Justin. My wife is nervous about me working by myself and I tweaked my back a few months ago that kind of shocked me to reality that I'm not as young as I used to be. Now I've been looking at things a bit differently in terms of how to accomplish them being a one man shop again.
OutlawDrifter
KS
Working by yourself is a bit of an art, and takes extra patience and thought. I'm also very specific about how I like things done, and have "control issues" when it comes to my shop and vehicles. I'm not very good at directing people down the path my mind has created a lot of times, and therefore, can get more done by myself.
When I need extra muscle, I call in the nephew (6'3ish 270lbs) or daughter #2's boyfriend. He stays focused, works hard, and doesn't require babysitting or constant instructions, lol.
dittle fart around
Vancouver, Washington, USA
My kids won't work with me. They can't read my mind, and I can't tell them what's in there without knowing myself.
:beer::beer::beer:
Z
zmotorsports
Northern Utah
Tried out the axle fixture last night and it works perfectly.
alexb2000
Fort Worth, TX
Mike-
Nice work as always. What (if anything) do you plan to do to keep the diff from rotating in the saddles when the U-bolts or links are off?
I use a set of chain vice grips to keep mine from doing that, but it requires the saddles on the stand to have a flange parallel to the axle tubes so you have something to clamp to.
Z
zmotorsports
Northern Utah
Axle stand looks great Mike, any chance of a video on YouTube?
Thanks Anders. I showed a little bit of it on my last video from this past weekend called Saturday Shop Tour #5 but I wasn't able to get it completed on Saturday.
I may do another video this coming weekend if I have enough projects lined out. I appreciate you taking the time to follow along on my videos and I've been asked to put out more videos so I am going to try to document a bit more of my work. I'm worried about though because I don't want to just throw up videos unless they actually have decent content otherwise it's just occupying space and everyone's time. Much of my work is just standard jobs or projects and only try to focus on the unique stuff or projects with a twist but maybe I'll try a bit more and see if people respond favorably or not.
I really appreciate followers like you that appreciate the content and my rambling though.
Z
zmotorsports
Northern Utah
Mike-
Thank you. I'm not as worried about the pinion dropping because this is just to hold the weight of the actual axle itself. When I have removed them via jackstands and raise the car up and away from the axle the pinion will sometimes fall downward and others times not as it really depends on the balance of the axle front to rear. When it comes to installing bolting lower control arms or upper control arms first is really irrelevant and then a simple movement up or down on the pinion will align the other control arms.
If I discover later on that a way to hold the pinion will be beneficial I'll cross that bridge when I get to it but I'm not too worried about it at this time. I merely wanted a means of raising and lowering the axle housing while the car is up on the lift which is what I have achieved. So far I've only used it once a couple of nights ago and it has worked perfectly. Last night reinstalling the axle went just like I described by moving the pinion yolk slightly to align the mounting points.
Thanks for the comments and for following along.
Z
zmotorsports
Northern Utah
I started another change to the Jeep a couple of nights ago.
When I originally built the Jeep back in late 2011 (over 100k miles ago) I added a BDS 4.5" long-arm suspension lift with the JKS ACOS front setup. The ACOS are an adjustable coil spacer that allows a couple inch range of adjustability placed between the upper spring bucket and the coil spring itself. It is designed to have the ability to compensate for changing weight and/or ride height of the vehicle and we all know Jeeps are never done and ever evolving so I thought they would work perfectly for my application.
That being said I don't think I would ever run them again. In the 8 years and just over 100k miles I have had my Jeep I have only adjusted them one time and that was about a year and a half after the initial build. I made about a 3/8" adjustment to compensate for some slightly taller springs I added to the rear in which to compensate for the added weight.
Personally, I would suggest that a person uses springs and if necessary a small spacer for final adjustment as once these are installed they are on there. Even on the JKS website they say these are irreversible. Although I am reversing them it comes with some time and effort.
Hands down the worst part was removal of the ACOS from the Jeep and I put a healthy dose of anti-seize on them upon initial installation.
A few pictures from last couple of nights work.
Passenger side ACOS removed with a little persuasion but really not that bad to remove.
Driver’s side was much, much more stubborn. Trying to free the driver’s side ACOS.
Passenger’s side assembly and lower portion of the driver’s side.
Finally. All the components removed.
Passenger’s side painted.
Driver’s side painted.
Stay tuned for reassembly.
Z
zmotorsports
Northern Utah
Looks good. Are you installing some fox air bumps in those tubes or what's the plan for bumps now.
Nothing that high tech. I was going to install some hydraulic bumps but for a daily driver/weekend wheeler that’s not built to run high speeds through the whoops that is way overkill. I’m going a much simpler route.
Z
zmotorsports
Northern Utah
Today’s work consisted of finishing up my Jeep suspension.
After removing the ACOS spacers that provide about 1-1/2” of lift at their lowest setting I had to install a bit longer spring to compensate. I have been so impressed with the ride quality and flex of the Metalcloak dual rate springs that I have installed in the rear that I again went with some Metalcloak coil springs for the front.
Here is a side by side comparison of the old BDS 4.5” coil springs compared to the new Metalcloak 4.5” dual rate springs with a higher spring rate. The Metalcloaks have a 22.5” free length which also prevent them from unseating at full droop.
OEM Mopar spring isolators that will reside on top of the spring between the spring and coil bucket. Also in the picture are TJ/LJ OE replacement jounce buckets. On a JK/JKU these jounce buckets are welded to the coil supporting tubes but seeing as how I cut them off when I installed the JKS ACOS & years ago I had to come up with an alternate plan. These will be bolted to the vertical tubes for an OEM function and appearance.
OEM jounce stops on the left and new Metalcloak Duro-spring microcellular urethane jounce stops on the right.
OEM isolator, OE style jounce bucket and Metalcloak jounce stops installed and ready to accept the new 4.5” Metalcloak coil springs.
Springs installed along with Synergy stackable bump stop adapters.
Shocks and sway bar links reconnected.
Rear OEM jounce stops with new Metalcloak rear Duro-springs.
Metalcloak rear jounce stops installed.
Final assembly and sitting back down on its tires/wheels.
Before backing it out of the shop and taking off with the wife for a drive I wanted to do one more small mod.
I have been disgusted by these ugly door nets that FCA thought were a good idea. Not only are they as ugly as Fido’s **** but they’re useless. I’ve been eying these JK Pockets for a few years but finally pulled the trigger and bought a set. I went with the standard black as I didn’t want the carbon fiber ones.
Thanks for looking.
Scuderia-F1
Stockholm, Sweden
I’ve somehow managed to miss your latest video but just fired up my TV to correct that.
Massive fan of your video productions no matter what job you’re tackling.
Just looking around at your equipment is massively inspiring and your ramblings are GREAT!:beer:
Regards,
Anders
PhantomEB
Medicine Hat, AB, Canuckistan
Them door pockets look way more cleaner.
That’s the one thing I always laughed at with the jeeps in my old club....ramp champs that always had their coils fall out. I was 27 at the time when they would ask what’s so funny... I go are you gonna be able to put a coil back in on the trail? Mine are captured top and bottom.
Z
zmotorsports
Northern Utah
Today my wife and I took off for a drive up and over the Mirror Lake Highway (US 150) out of Evanston, WY and down through Kamas, UT.
We put about 250 miles on and put the Jeep through its paces as well as just relaxed with the wife and enjoying the drive and conversation.
The Jeep is so planted and sure footed through the curves even at speed and flexed out nicely on the couple of obstacles I tested it out on today.
We even saw a few people out on the little kettle lakes ice fishing although I don’t think it was thick enough and especially with it being in the mid-50 degree range today.
Thanks for looking.
Z
zmotorsports
Northern Utah
I sure am Matt.
Love these 37’s. The Nitto Ridge Grapplers worked great in the snow today.
Mileage out of this LS is pretty good as well. Pushing a 6k pound brick down the interstate @ 70 MPH then up over a 10k foot mountain pass at 45-60 MPH a few miles of snow-wheelin’ and still netted me 16 MPG when I filled up back at home.
lilscorpion
Colorado
I sure am Matt.
So jealous. Maybe in the spring for me but until then, I’m more than happy to live vicariously through you. Need some LS vs. deep snow bashing pics now. [emoji6]
Sent from my iPad using Tapatalk Pro
Z
zmotorsports
Northern Utah
Matt, I had asked my wife to jump out and take some video of me driving through the snow but she just looked at me and said "are you kidding me? It's warm and dry in here why would I go out and walk around in the snow and get cold and wet?" I actually couldn't argue with that logic.:lol_hitti
