zmotorsports
Looking good Mike, I like where this is headed!
Thanks Marc. So far just some ideas bouncing around in my head and kind of planning as I go.
I’m sure you’ve said before, but with 200+ pages to search asking is probably quicker! On your fab table I seem to remember you modified the ViseGrip clamps, but what are the slide clamps, and could you give us rookies a refresher on your system/setup? TIA!
So the 5/8 bolts are threadless? They just slip into the holes in the table and then the slight sideways thrust locks them into the table? My fab table is a steel drop 1 1/2“ thick by 2’x4’ and I got a Milwaukee Mag drill from my dad. Just thinkI got this might be a good project and make setups a bit more precise. Photos of your clamp and table details would probably help my comprehension a bit!
HoldfastsI've got a contractor that has an antique table with the inverted J-hooks but I don't remember what those are called.
Mike, did you see my PM?
Thanks!
Mike, Just a thought, the connection from the main frame to the horns seems to be too sharp of an angle for the flowing lines of the horn. Adding a bit of a reverse radius at the beginning of the cardboard before transitioning it to the arch of the horns would help it smoothly transition a bit better. Now, this is just my thoughts but wanted to share, feel free to put me in my place if you don't agree and I'll continue to bow down to the master at work.
JB
Seems like you scored yourself a great tool for very reasonable money & also got to show some proper craft.I forgot to post pictures of when I was milling down the Cummins feeler gage the other night so I snapped a few pictures of the setup last night before I broke it down.
The correct thickness feeler gage that I need to set the Jacobs Compression Brake on my ISL is not currently available and I've been watching for a used or new one on eBay for several months now with no luck. Also the Cummins/Jacobs feeler gages are very expensive at around $85 at the low end for an aftermarket one and upwards of $160 for an actual Cummins tool from the local Cummins dealer. I put a $50 limit on myself while trying to locate a used one in good condition. As I was growing nearer to the time of needing it and unable to acquire the tool I figured I would just fabricate one and move on, but I really wanted the actual proper tool.
I luckily stumbled across a Cummins tool a few weeks ago on eBay, however, it was the incorrect thickness but it was only $25 and new in package. I'm not sure if the seller didn't know what he had or just obtained them at a discount and wanted to pass that savings along to others. Either way it was too good a deal to pass up and figured I could machine it down to the .090" thickness that I need but I worried the harness may not be conducive to machining. I thought I'd roll the dice for $25.
I set it up in the mill vise and used a multi-cutter facing mill and was surprised that with light cuts (.015") it actually machined quite nicely. It took a bit of time to go from the .276" down to .090" but it was well worth the effort for the results as the finish turned out very nice.
Thanks for looking.
Seems like you scored yourself a great tool for very reasonable money & also got to show some proper craft.![]()
Frozen doors are no fun Mike!
Looks like you had quite a bit of snow to move, my best friend up in Sioux Falls is currently dealing with a similar situation.
It was early in the morning, you get a pass!
Wherever you wanted. Nobodies going to tow it awayBut then there's the storage issue. Where would I park it?![]()
This ^^^^^^^^^!!!!!!!!!!!!! And you are not getting any younger my friend.I don’t know Mike, but when you have more concrete than a Walmart parking lot, you may need something a touch bigger for snow removal!
Person with mad fab skills could mount that to an RV ... just saying![]()
You're welcome Mike. It just a small service that I provide.You guys are hilarious.
And your right Dan, I'm not getting any younger so thank you soooooo much for pointing that little tidbit of information out. Really made my Friday my friend.![]()
