I appreciate the comments everyone. I am flattered at the comments everyone has made. Another reason I love this forum. Everyone is quick to assist and help to uplift one another rather than tearing them down or making them feel worse.
That turned out to be a **** ton of work but the majority of it is done. All that is left is to paint it, which my son is going to do tomorrow and then we should be able to stab it back in Monday night after work.
I started removing the axle from the Jeep about 9:00 this morning. My son had to work part of the day and by the time he got home around 10:20am I was ready to have him help me lift it on to the axle stand. By 6:00pm we were cleaning up and it was ready for paint. No breaks and no stopping all day. Once we got going we just motored right along until it was done.
Some of the welds that were easy to access I cut with a cutoff wheel on a die grinder and the remainder I widdled away at with the plasma cutter.
The gussets were the first thing to remove.
I then went in and blended everything with a 2” and 3” Roloc disk in preparation to start cutting the welds for the knuckles.
I also figured I would remove the paint from the track bar mount as we would need to angle it slightly in order to keep the track bar moving straight in the vertical plane.
Then it was on to cutting the welds for the knuckles. I thought I would try using the plasma cutter at an angle in order to try and scarf the weld out. Angling into the joint of the knuckle with just a little more emphasis on the knuckle rather than cutting into the tube. It actually worked well and was quite a bit faster than I imagined.
Next I went in with the grinder to remove the slag from the plasma cutter which disappeared quickly.
Lastly I went in at an angle with a 1/8” thick x 3” wheel on a die grinder to remove the last little bit of weld before smacking with a hammer to try and expose a crack.
Here you can see the depth in which I had to go.
Next was to put some reference marks on the outside of the tube as well as the inner tube to knuckle. If you look closely not only will you see the reference mark in the picture below but you can see the crack appear after a good smack with the sledge hammer.
Here we are at our target.
Side closest has been clocked and the far side hasn’t.
After both sides have been turned the same amount, I burned in a weld to each knuckle and tube bouncing around and side to side to control the heat.
Then after triple checking the knuckles with the angle finder it was time to install the new gussets.
Lastly after the gussets were complete, we moved on to the track bar mount and also installed a fish plate on it for a little extra strength, although probably not needed as the Artic Industries bracket that we installed is 1/4” plate and very nicely braced.
Cutting, welding and fabricating done and the axle is ready for paint.
That’s it. DONE! That was a long nine hours of work today but I am glad it’s done and looking forward to the road test.
