Last night after arriving home from work I thought I'd take a few minutes and connect the Noco battery maintainer on the Camaro. I had let my last one go with the Harley back in August and hadn't purchased another one for the Camaro until right before Christmas. I had the wife order one and it arrived last week but I didn't have time to mess with it until last night when I made time.
I pulled the cover back, popped the hood and connected it to the battery connection points while monitoring it with my DVOM to ensure everything was working properly.
After watching it for a while I closed the hood to the first detent and reinstalled the cover and put her back to sleep until we get some nice weather. I also still need to do a full paint correction sometime before spring.
I then continued on with my next project that I pulled in the shop the night before. My 2006 2500HD Duramax, although my wife informed me the truck and Camaro are hers now. Not sure how I lost two vehicles in a matter of months.
The wife said I never lost the Camaro because it was hers from day one.
Truck racked with the hood in the service position. I also need to replace batteries so they were removed from the engine bay.
Here are the parts I'll be needing for the job at hand.
Front tires removed, passenger's side inner wheel well removed and coolant draining by pulling the lower radiator hose as this vintage of GMT-800 chassis does not have a radiator petcock.
After draining the coolant the night before and allowing it to fully drain I replaced the inner O-ring and put the lower hose back onto the radiator spigot. I have NOT had good results reinstalling the lower hose with a used O-ring in the past and seem to have weeps so now anytime I pull a lower hose on a Duramax I replace the O-ring. Sadly, you cannot buy these O-rings from the dealership or anywhere for that matter by application so I had to spec out the O-ring and order them by size years ago. I ordered enough to hopefully last me a lifetime of pulling lower hoses. A little Sil-Glyde was applied to the O-ring before inserting into the groove and then another light smear after it was in the groove. I then run a light coating around the tapered spigot on the radiator to aid in installation without damaging the O-ring.
Lower radiator hose slipped right on and then the lock ring installed.
Which this application of Sil-Glyde brought me to the last of the tube. I've had this tube for many years and it looks like it's time has come to land in the trash can.
Time to break out the next tube in line of succession.
And a new tube on deck.
Thanks for looking.
