Re: Innovation & The Workbech
If not, it would be easy enough to make it so... It's really the idea that I'm freaking out about.
I can't quite figure out what it is about this table but I really like it. Simple yet shows a lot of thought. It appears
to be an old set of shutters off of an old house or perhaps a set of doors off of a small cabinet of sorts. I would guess that the
frame was built around the doors, already had the doors and just made the frame to fit. It could be modified in
several ways. I would put some simple straps on the pockets to hold the contents in while the top was closed. Just a strap
with a snap on the end and fasten it to the underside of the top. I would think about making a bigger tray to hold things. I
am guessing that the tray on the top of the desk will fit in the frame on the right hand side.
You could also re-configure the clamp that holds the light in place, maybe a shorter thumb screw the would allow
the light to swing down under the desk when not in use. Something to allow the clamp and screw to sit in the recessed area
on the bottom .Only drawback to this is that you could see the light hanging
down under the desk when the lid is closed, and it would not let you make a bigger tray for under the desk. You could
even change the light to one of those old rectangle headed lamps and could make it fit in a tray under the top. I don't
know if it has it already but since the front also hinges put a set of pockets under there too for things you need to
keep close by but might not need that often.
Randy
