Show Your Vintage Compressors
chopper1
Member Emeritus
Ohio's North Coast & Florida's West Coast
Got the idea after seeing Moloko's post.
Lets see those old compressors.
Mine was built by my step dad in the mid 30's when he worked for US Air Compressor during summer vacation from high school. Half horse Leland motor, the tank is 1/4" plate rolled and welded. It builds about 125 PSI and I have no idea of the CFM. It's only good for filling tires and blowing off dust/dirt and filings but I can't bring myself to get rid of it.
Brad54
There's a lot to be said for having a little "utility" air compressor in the garage--especially one that was built by family.
Obviously, you can't ever get rid of it!
-Brad
cglasgow
1959 Gilbarco. This was right after I brought it home & cleaned it up a little. It still needs to be plumbed in but it's in working order now....
(& yes, I know the shop is a disaster area... ;-)
Steve from Socal
Hutchinson Ks.
This is my relic; it was purchased by my dad in 1972~73 and has done a lot of work for a 1 1/2 hp compressor including running two in ground hoist at my old shop when we first moved in. I have painted two cars, an airplane and lots of ice repairs and, several machines with this little dude. It is a very well built compressor and it has been a real work horse.
Steve
spongerich
Monroe, NY
Here's mine.
The compressor says "Cadillac"
They're definitely no longer at 3 Howard St, NYC. There's a Chinese restaurant there now.
jniolon
hueytown, al
I don't know how 'vintage' mine is It's a quincy 310 and it's a hoss...
I've had it about 20 years and it's never failed me yet... sorry about the picture, it's in the intermediate wiring stage at it's new location (in the attached shed)
marko
Uk
Hi, 1st post here from a classic compresser owner in England :) several years ago my trusty 1966 Atlas Copco gave up the ghost and has sat disused since :( i've searched high and low for spare parts but never found them.the problem is the disc valves have gone in the pump and are now missing as a few peeople have offered to take a look at them and are now as good as lost..
any help getting this old girl back up and running would be awsome, the pump has KE2B2 on the front plate.when up and running i plan to completely restore this but i need compressed air to do this!
Skin
Boston
both the original disc valves are lost? i was going to say any decent metal shop should of been able to fab you replacements. Old ones were made out of copper-beryllium i believe but spring steel would be a better modern replacement. This is quite commonly done with reed valves, disc valves shouldnt be any more difficult.
Even if you still have an outline from the head i'd trace it, or just take the head itself, and bring it to a competent metal fabrication shop. The only thing you'd be guessing at is the thickness. Probably would be expensive to make it worthwhile, but depends what its worth to you to get it back up and running.
Did you try contacting Atlas Copco directly? They still make compressors with disc valves. At the very least perhaps they could give you an idea of the proper thickness.
marko
Uk
thanks for the reply, only one valve failed but i gave one to a friend of a friend to look at and never got it back, not sure what i did with the good one (i must have given that to someone too to look at :headscrat).
i can look at it from 2 ways, one is to just go and buy a new compressor, say a 50ltr tank with 2-3hp or fix this one up, it's a 150ltr monster but in reality the 50ltr will do me and not take as much garage space up!
i have just contacted atlas copco again to see if they can help, i would be happy to put a new complete pump on if i knew where to get one from!
Mark.
marko
Uk
just found THIS on a website (Clark pump), looks ideal apart from i'm not sure about the hose fitting to couple the pump to the tank. no idea where/how i would sort this!
3944r
That is a Quincy pump I believe, the pressure gauge is a tell tale sign
hemifalcon
Union Grove, Wisconsin
Not too old--but it's a 1972 Kellogg-American unit.. I have plans to get it cleaned up and then I have to get my garage wired to make it live...Just picked it up today..
Got this old 1945 Westinhouse Air Brake 80Gal tank as well.. Gonna need to find a home for it though..
fotojack
I have an old 1961 tank with a 1953 pump on this compressor that was given to me recently. I'd post a picture of it, but I can't upload from my computer. It wants a URL. Any way around this?
VEGA66
Minnesota
Long time browser of this website and finally created a profile because I needed more access. Figured I'd post about an old C-aire compressor I bought and am currently re-building.
8
gobeer net
Arkansas river valley
Not exactly vintage, but old enough I can't identify it. A friend picked this up at a local yard sale. Can anyone identify this? Seems to be cast iron bottom with aluminum cylinders? Spins but doesn't pump up.
cjdazy
Am getting rid of some things since my husband died and was wondering
if anyone could give me a rough idea of what this compressor might be worth?
Don't know if it runs, but Neil had it tarped, so feel it must have some value.
Tag on it says Champion Pneumatic Machinery Co., Chicago, USA. Model OE 34 60 F. There is another tag on the motor says Wagner Electric Corporation. Hate to just scrap it if it may be of use to someone. Will try to upload couple pics once I figure out the URL thing. Appreciate any info.
Sir R
Winnipeg,MB.Canada
I have 3 vintage compressors
Blue one is a 55 Quincy
The red one I'm trying to find out what that one is , the bigger beige one is just a generic pump. ID says 101-K
Anyone know?
Johnnydeez
I’m trying to find out about this one. I can’t find anything even similar to it.
