Looking for some help identifying the problem. I just changed the oil in my Quincy QT 54 air compressor and when I turned it back on to run it the Baldor 5hp motor started smoking. The motor starts fine, even my tank fills up, but the motor is smoking and smells like burnt electrical or plastic. Motor is pretty hot, but the thermal overload doesn’t kick off. Everything worked as normal prior to changing the oil, all I did was drain oil, put new oil in and changed the air filter. Never had this issue before. Any ideas?
Oil is same stuff I normally use:
Video of smoking motor
