I got mine today... I had it delivered to work, figuring that the receiving guys could use the forklift to unload and help load into my van. Well... the truck got there at 5PM and the receiving guys had already left. DOH!
So, I rounded up a few coworkers and headed to the loading dock. Luckily the dock is one of those hydraulic ones, so we just raised it up to the truck level, slid the package onto the dock, then lowered the dock to my van level and slid it into there. With 4 people it was still pretty tough... and I'm REALLY glad the truck driver was really helpful with getting it unloaded AND loaded. Unfortunately, I didn't have any cash, or I would have certainly tipped him
. I'm buying the guys at work lunch tomorrow
But yeah, once I got it home, I just popped off the straps, pulled off the cardboard and plastic wrap and unloaded piece by piece, which were all very easily managable. The last two things which were bolted to the metal frame were the two arms, and I just unbolted them and stood them up, then grabbed my handtruck and took them into the garage. If I was to do it again, I would have disassembled it on the loading dock and loaded it piece by piece into my van. You need two large wrenches (or channellocks) to undo the bolts, and tin snips to cut off the straps (those are some tough straps!).
Unfortunately, mine had one part damaged in shipping (at least that I've found so far). The spring loaded release rod on the bottom of the arm is bent. It still moves, but doesn't bottom out on the bottom plate. It shouldn't be too difficult to replace (I'll call Dannmar in the morning). And like richashley, mine had some paint damage, but nothing worth worrying about. Also, I thought I had ordered a rolling work seat, but I didn't see it in the shipment... I'll have to check the packing list to see if it was supposed to be there (I assume not, since there didn't appear to be anything missing).
Overall, it looks very nice though... hopefully I'll be able to get it set up in a month or so and give it a try! I've still gotta run electrical to the garage, and I'd like to put down an epoxy floor beforehand. BTW, attached are some pics of it in my van, and the damaged rod. Hopefully this will give you guys an idea of what you're in for when you go to unload and load one of these.
Edit: Yep, I just checked the packing slip and it shows that the rolling work seat was backordered.
Pat
