octane_matty
Another weekend and 1 step forward, 2 steps back
Thought the shifter setup was good but the sides were a little too high for comfort
Alot of grinding and ugly welds later
Finally centered and high enough in the tunnel
cut/welded the shifter rod and shortened the shifter assembly until we're at an acceptable height
Lower than stock but probably not as low as a ZHP knob
Recently purchased a fresh set of AD08Rs
Turns our 285/30/18s are being phased out so i nabbed a set quick
Initial fitment check is
Front is a different story with 265/35/18s
Suprised the AD08Rs are a very wide tyre in 265/35, measuring around 272mm
With about 2.6deg camber i'm pushing the absolute limits of my fenders.
Beyond 2.8 degrees probably isn't feasable for a street car
Hopefully when they're mounted on a 9" rim it will pinch the tyre a little and i can make some more adjustments on the coilovers. (Already removed the helper spring)
I know what you're thinking;
With the rears a 275/40/17 would be ideal but it's beyond the maximum diameter allowed by 1mm.
Run a 255 or 265/40/17 then stretched? Nope, the maximum allowed rim width for a 255 is 10"
It aint easy trying to keep within the rules
ETA to completion: 149.6hrs only 11 weekends to christmas
Unfortunately shifter changes put me behind again.
Recent Purchases: Intake boot,custom brake lines and some titanium
Cheers for reading
- Why not run a 245/35/18 tyre? they don't really make them anymore in a matching set with decent rear sizes.
- Why not run a 255/35/18 over a 265/35/18? unfortunately 255 AD08Rs are below the legal load rating limit 90, i need minimum 91 (615kg)
- Why not run the 17" CCW rims;
Cheers for reading
