Above 1200 Sq/FT building my BIG PARTY garage
Dan in Pasadena
Pasadena, CA
That's an interesting question Cobbler
I've been in guy garages that collect the same style stuff and you couldn't hardly walk through the place more than single file.
With that thought I have a V E R Y L O N G way to go before I would be full. That said. It takes a little time to figure out where to put the next piece that I bring in now and the few pieces that I set out for the sand blaster today have no place selected inside yet.
To answer your question I can only say that the hunt is as much of the thrill as the buy is and once that purchase has been made it's on to the next quest. The one thing that is starting to hold me back some is the amount of energy I have left to work on all the treasures that I find vs what I already have in waiting
Three words: "BIGGER Party Garage" Lol.
D
don long
southern california
Now about the Blackhawk jack. The chrome is home and where it needs to be shinny it is. Some of the chrome will be painted over so the shop didn't spend as much time on those areas. Only the arrow on the lift bar will be chrome, the rest will be red and the cover plate will be all red less the letters spelling BLACKHAWK. They will be chrome. (I'm hoping that it turns out well)
Here are the chrome pieces tonite
Dan in Pasadena
Pasadena, CA
Damn, those parts look great, Don.
Gotta admit, it would kill me to scratch up the new chrome to apply paint over it! (Or do you have to? Is there some kind of primer that will adhere well without having to sand the chrome?)
D
don long
southern california
Thanks Dan
Nothing that I know of. That's ok because the top plate isn't straight yet so I'll be putting a little bondo on it anyway.
Ann laughed at me when I showed her the plate all masked up and she said "you paid to had that whole thing chromed just for that"
D
don long
southern california
curious , when you run out of room in the party garage, will you keep collecting? :lol_hitti
After Cobblers comment I started thinking and looking around the garage to see what I could do to make more space for treasures, and discovered that I had extra room not being taken advantage of
So Today I started a new project inside the Big Party Garage
1. Hiding a couple of ugly posts
2. Making room for more treasures
3. improving the lighting under the parking area
With a couple new walls and a shelf between them I will have a place for a new collection or move over a crowded collection or move one collection so I can put something from the container back into the garage.
All for you Cobbler
D
don long
southern california
D
don long
southern california
This afternoon the project new shelf in the BPG looks much closer to being finished. After putting up the studs and figuring out where to put the Electric boxes for plugs, the plywood was cut and nailed onto the structure. Then I mounted the shelf hardware (angle iron and el brackets) before covering the plywood with paneling
Next came the shelf. I found a couple of laminated boards 14" wide and 20' long that would work well for the shelf. I wanted a shallow shelf along the side of the walls so I added a 2x10 plank to sit between the 2 wider boards. I cut the wide boards so they ran down the side of each wall and also covered some of the area between the 2 walls. So my shelf is 14" + 91/2" + 14" making it just short of 38" wide.
I tied the 3 boards together in the center of the shelf on the bottom side with a 1" angle iron to help stiffen up the unit.
After the shelf was screwed to the brackets I covered all surfaces with more paneling and started pinning the corner trim to all the corners and base board top and bottom.
Tomorrow I have a mobile sand blaster scheduled to work in the morning Then I hope to finish this project in the afternoon then I can get back to work on the Phone booth
D
don long
southern california
The sand blaster arrived this morning and went to work on several pieces I had out for him and in a few hours he was ready to leave. Giving me a bunch of work, Taking care of the fresh exposed metal.
I've managed to get 5 of the pieces into the booth and primered tonight
A blackhawk tool box
An old mechanical curb jack
2 sides of the english phone booth (Man these things are heavy)
And pieces of an old street light pole that will make a couple of nice stands for future projects
D
don long
southern california
I so badly want to start working on this Double rolling lubster now that it is cleaned up, but I'll just put it in primer and wait til I get that phone booth done before starting a new project.
And I've been wanting to restore a stand up spark plug cleaner for a few years too so I stuck one out in the field to help move one along
You can still read the print on the front panel if you look closely
And last is the mobile grease station that fell into my lap a couple weeks ago. It's going to take a little panel fabrication to make it presentable again. The back panel is missing. It will go into the Texaco gas station when It's ready
Bears Fan
Indiana
img_2760-jpg.1879207
That doesn't look like work, that looks like fun :cool: (y)
Dan in Pasadena
Pasadena, CA
All very nice. I'm with Bears Fan, I think it looks like fun!
But you have bitten off a chunk of work this time. Did you move ALL that stuff into your booth for priming? By any chance did you spray any of it outdoors? I don't know if you have the ability to do that and enough hose but some of that stuff is so damned heavy it'd be an effort to get it all in and back out again in a day. Can you prime over a couple days without worrying too much about flash rust?
EDIT:
I just re-read and realize you painted the stuff over a couple days. The new shelving looks real good. Smart to position the long shelf to cover the joint between panels and the trim makes the whole thing look very nicely finished.
D
don long
southern california
EDIT:
Hi Dan
Yes I can wait about a week without priming as long as the pieces are inside a building and not out in the weather.
I still have 3 pieces that didn't get primed but are inside the shop and some sitting in the booth
I'm headed to Tacoma in the morning to catch up with Jaberwaki to pick up a couple more treasures so I'll be busy next week. Should be home before Mothers day is over on Sunday
D
don long
southern california
D
don long
southern california
I mentioned that I was headed to Seattle at the end of last week. Well I left Thursday Morning and returned Saturday evening.
I visited with 3 GJ members along the way and each one contributed treasures for my trip.
I met Provincial On Friday morning and had a very nice visit getting to know each other and when it was time to go I had a Blackhawk tool for the Chevy board and an old wheel wrench. Thankyou Provincial
Next stop was with Drivesitfar. We had a nice quiet visit and a great Italian lunch just outside Tacoma. He surprised me with several nice treasures. starting with an old Blackhawk Red Rover box. Then 2 gorgeous Vices and an old blackhawk A29CD toolset
Last stop was with Jaberwoki
He loaded me up with 4 floor jacks 6 bottle jacks 2 alemite greaser tanks and an old lincoln welder that weighs a ton.
It was a very fun little road trip with new friends to enjoy
Thanks guys
Bopbop
Savannah,Ga
Don,
Those are some nice finds. The old Lincoln welder brings back some good memories. My daddy taught me to weld on one like that when I was 12 or 13 some 45 plus years ago.
John (Bopbop)
Dan in Pasadena
Pasadena, CA
Damn, Don! Saturday of the next week, right? Sheesh! I drove to Seattle last June to two home a 16ft enclosed trailer with my little Gladiator and spent a night in Oregon and I still felt like I was pushing it.
drivesitfar
Don: if I would have not missed your PM I’m sure I would have had more to give you. I was happy when you called and gathered a few things and jumped in my old Honda so I could see you in person cause it’s been waaaay too long.
Next time you come up we’ll have to go to a 50’s diner for burgers and shakes which I totally forgot about til after you and your brother left.
Or just fly up with your bride and I’ll pick you up at airport and we’ll make you a home cooked meal or two or three.
It’s always great seeing you and chatting so keep above dirt another 20-30 years so we can do this a lot more.
Thanks again for making the trip.
D
don long
southern california
That's quite a haul 🚚 🚛
Thanks Tony
It was a quick trip meeting good guys and having great weather to travel in. I'm sure that I won't be needing any new projects for a while.
That's some nice stuff Don, should keep you busy for a day, lol. I love that oil cart you blasted, I would like to find a single to put in front of my shop.
Thanks Jim
Most of what I brought home was a surprise. I knew of a couple of jacks and a wrench. It was great meeting new friends and renewing friendship with Drives (he stopped by the garage a few years ago)
Don,
John (Bopbop)
I too used a welder like that a hundred years ago John
I am happy to add it to the garage
No Dan
It was just a quick 2500 mile run in 3 days with 3 shopping stops lol
Thanks Buddy
I'll keep the air port idea alive in the back of my mind. You really surprised me with your donation to the BPG
Thanks again. Lunch was a fine visit. Food was good too
D
don long
southern california
So Today I managed to go out to the shop and get some 5hings done. My focus is on the English phone booth and tonight I have 3 of the 8 sides of the booth painted
The back of the left panel is painted
Next I masked off the window area and covered all the holes so not to get overspray on the fresh paint
Then turned it over and painted the front side
Then pulled it out of the booth and ran the right side and the door panel in to the booth for primer.
While that was drying I sanded the back side of the back panel and when the primer on the other parts was dry I traded places with the back panel and painted it
