Nautical fabrication
y'sguy
Tulsa, Oklahoma
That's turning out beautiful and I am not surprised. you do stellar work. I did not it expect it to be painted though. Still, looks fantastic.
R
royce
fairbanks ak
Just be glad you don’t have a Newfound dog in your shop. The hair is enough to become a structural component in the epoxy
Hey Riv,
I made sure to color coordinate the boat with the pup!
Last coat of paint on the interior and not a moment too soon.
Royce
R
royce
fairbanks ak
Got the rudder hardware, transom cap, bilge pump, bow cleat and chocks bedded and fastened today.
Next up, floorboards and thwarts.
Also took delivery of the sails, now if I only had some spars to hang them from!
Royce
R
royce
fairbanks ak
Thwarts and floorboards in, oarlock sockets glued in, centerboard and hinge pin in.
I think she's ready to row, maybe tomorrow.
Royce
Bears Fan
Indiana
img_4396-jpeg.1906472
Beautiful :love:
Firstram
This is one of my favorite methods of joining beveled parts, it's the only way to go. Self aligning, extra glue surface, super easy to hit your dimensions, only one angle to deal with and it makes tapered columns a breeze! Curious about the overhang, I have always run the dado deep enough for the parts to corner up. I guess if you're rounding it over this method would leave a full width glue joint and allow you to plane only one board (competing grain directions).
Beautiful work, as always!
R
royce
fairbanks ak
Thanks Firstram,
I opted to cut both sides of the birdsmouths at 45 degrees for simplicity of saw set up.
To get the corners to align, I would have had to have two different miter angles, depth and fence settings to make the joint.
Like you wrote, the corners will be gone when shaped round.
This is a first for me, building hollow spars, so I don't know much about it.
Royce
R
royce
fairbanks ak
I was looking for Royce's build page for the lathe he was going to chuck this up in to spin it round and smooth.
I do have a lathe, but would need to make a tailstock for these long spars.
Not sure yet, if I'll go that route or not.
Royce
Firstram
Thanks Firstram,
The beauty of this method is you square cut all of your parts to the visible size and then dado one side to accept the other at whatever finished angle you need. You can set the dado deeper to make the outside line up but you do lose glue surface. Only beveling one side is needed regardless the number of sides or depth of the notch. What you have is probably the strongest end result possible after you plane it round!
Royce
A lifetime of experience always comes into play, steel and wood aren't that different. My dad always told me, a carpenter makes a better welder than a welder makes a carpenter because glue wont fill a gap. I disagree, either you get it or you don't.
You get it! Thanks for taking the time to post the journey
WoodsTruck
It almost looks like the outer corner could be trimmed individually with a table saw set at about 60° to speed up the clean up later.
But what do I know?
Firstram
Thanks Firstram,
Royce
Re-reading this, I guess you cut that birds mouth with a saw blade. Next time consider using a 3/4" dado blade stack set to your angle. With a sacrificial fence exposing just the right amount of blade it's a 1 pass deal. Beautiful work no matter how you got there!
R
royce
fairbanks ak
I have 5 more spars to make for this boat and really like the idea of a dado stack and one pass.
I think I'll give it a whirl, Thank you sir.
Royce
