Yet another thing being refurbished
Shiftless
East Bay SFO
I remember those old fluorescent lamps with the starter button you had to press for a few seconds and then release to get the bulb to light up. Cool project!
skeer
Standish, MI Area
Yup, it’s a Dazor P-2134 I think. I can’t find a single pic online of this base though. Tore it all down Saturday, ripped out all the old fabric wrapped wiring, and did not snap a single screw. The base steel parts are soaking in the derusting bucket but all the cast parts have been repainted the original chocolate brown.
I thought the switch was a goner but after drilling out the two rivets the insides were just fine. The two buttons needed some touching up as they were stuck in the top plate.
Going to run leds in this guy.
Shiftless
East Bay SFO
I’m not familiar with the wiring on those, but to run LEDs I think you’ll need a different switch.
You could leave the original 2 button switch for looks and put a simple on off rocker switch down on the base.
Adaylate
Washington
The tombstones in mine were quite brittle. Super glue was my friend. Some new wiring a two new tubes and it was 1950 again.
good luck with your project!
skeer
Standish, MI Area
I ohm’d out the switch, it’ll work as a normal one if so reverse the buttons. Black is straight through when Red is depressed. Neutral can be unswitched.
skeer
Standish, MI Area
Whelp I somehow done effed up. While trying to keep tension on the spring in order to get the first elbow connected the spring block popped out and relieved all the built up pressure.
I feel like the lamp is royally screwed now.
Any tips?
skeer
Standish, MI Area
Gfdi. The lamps trash now. I think when I was trying to lower the support rod in order to pin it down to get enough space to reassemble that first elbow.. the large tabs flexed just enough for the spring brace piece to become dislodged.
FML. Now I lack the equipment or the means to retention the spring. Talk about dashed hopes.
Shiftless
East Bay SFO
Please accept my condolences on your situation.
I suppose now you have 2 choices… Store those nicely repainted parts in the hope that you or a buddy can figure out a fix sometime in the future... or pitch the whole thing and move on to something else and try to forget about that Dazor. If that’s the worst mistake you’ve ever made in the vintage restoration game, consider yourself lucky.
Bert_
NW Iowa
So the spring brace you are talking about goes between the notched parts? And the spring is curved part with a hook on it?
skeer
Standish, MI Area
So, the hangy down part with the inward curved piece was braced against a rod with flattened ends that fit in those notched parts. That’s what gives the entire arm it’s lift.
There’s a small 90*-ish angle piece that the main spring uses to keep itself under tension.
The thick curved piece you see in the picture underneath the notched parts goes back behind everything and is braced from the back side of the notches.
I’ll get some MSPaint-like editing later to help show.
skeer
Standish, MI Area
I'm sure someone has fixed this before?
I contacted Dazor;
Unfortunately, the parts needed to repair/rewind the spring are no longer available.
Sorry we could not help.
Thank you,
Dazor Lighting Technology
Yeah see you know they have someone who knows the process to set this back up… but def appreciate the ask. I couldn’t find actual repair or even warranty links directly on their website.
Bert_
NW Iowa
Bend some rod or flat stock into a hook so you can get leverage and twist the spring back up
skeer
Standish, MI Area
I thought about that.. I need to figure out how to brace the bottom well enough. The assembly doesn’t have a ton of room to clamp or hold it. But that’s an idea.
skeer
Standish, MI Area
I might have just lucked out.. it'll be next week before I know but I pinged a guy on FB down in Detroit selling a P-2134 that looks pretty immaculate. He was asking $20. He sent him number and we chatted for a few.. he's planning to ship it to me sometime middle/end of next week. Even says I can wait to pay him until it gets here and I make sure it's all good. Guy said he's in demolition, finds stuff all the time and found this ~3 years ago and never did anything with it.
Of course I still want to fix this one I've got but, maybe someone could use all the other parts to restore their own?
skeer
Standish, MI Area
An idea strikes!
How about a normal coil spring, a very stiff one. All thread running through from top to ballast enclosure. Support rods ‘prop’ being supported by the edge of the spring. And using a nut to adjust tension by raising the spring up or down. Only real issue I see is; A. will the spring be enough to keep the lamp head aloft and B. Keeping the top half of the spring from being shoved too far away from the body.
Sinatra
Will a worm gear hose clamp work around the spring to temporarily retention it? I can‘T tell from the photo if there is room.
Zeke
If all you have to do is get the hook up where one of the notches are and insert the rod, weld a 2' long rod on the hook and bend it up there. Seems as there are more than on notch it is adjustable for tension. If it is adjustable then someone can adjust it. If you're having trouble holding it put one side of the spring housing in a vise and wind the spring in the horizonal position.
If you don't have a welder drill the hook and double nut a hardened rod to it. Or use a long tight fitting drift with a cheater if necessary. There is no stress on the high part of the hook arch.
Bert's idea might work if the flat bar doesn't bend or run out of room. You can add stiffeners but at one point you'll have more work in the tools to fix it than the lamp itself.
Jim_No_Garage
Millington NJ
I'm following this conversation as I had a similar issue with one of my many Dazors. The parts are resting in storage hoping for a creative re-use somehow.
Cheers
Jim
cbks1
Any tips?
As I stated when I Registered here, I had the same thing happen to me, it scared me dodo less, but even more-so when I looked down and saw that it had nearly severed my index finger. Contacted Dazor and was told that if I was lucky my index finger was all that was damaged, but that if I sent the unit into them that they could recompress the Spring. I never did, I had three more of them.
skeer
Standish, MI Area
So after you take the nice covers off the sides there is the u shaped frame right?
I drilled a small hole straight through that right down where I could slide a nail thru that would engage with the ‘teeth’ of the, well… whatever you’d call the cam side?
Anyway I pulled the rotating part up and out of the clamp base. Put the u frame into the Vice and inserted that hardened pin ito the teeth that the wheel uses to transfer tension to the wheel.
Carefully pried against that pin and slowly worked that toothed wheel until I could slide a finishing nail thru the drilled holes.
Then a smidge more prying was finally able to get that fulcrum lever piece to engage with the tension pin.
Idk if that’s followable in the least…
Jazz1
Thunder Bay On.
Looks similar to lamp i picked up at the Sally Ann few years ago for $8.00 although. I never had to do any work on it.
skeer
Standish, MI Area
Damn, If you found a Dazor for 8 bucks then you really ****! Lol.
Received the t8 18” leds today, wired her up using the original switch and man. “She’s a beaut’ Clark”
cbks1
Beware that Spring, I leaned the Hard Way, (the part shown in your Pic. hit my finger, snapped it at the joint), its under tremendous load. spoke to DAZOR, they can repair these if needed.
skeer
Standish, MI Area
Ooof damn man, your finger has my sympathies.
Yeah I'm learning that I likely put the upper wheel back into the frame backwards. I mean.. it works.. it all works good, I can grab the lamp head and move it all over the place but at rest it just looks, not totally right. But I don't care! I'm not about to take it back apart.
Old Moparz
Newburgh, NY 12550
Cool to see another old thing being saved, I hate tossing things out. (y)
I have the same light, or a very similar one, that I have been saving to use with my drafting table. I don't do any mechanical drawing anymore but plan to set the table up in my second floor room of the garage for my wife to start doing her stained glass projects again. Right now it's clamped to the end of my basement workbench.
I thought I had a better photo of it but it's gone. :unsure: You can see the base of it on my workbench next to my project manager, Igor.
skeer
Standish, MI Area
Nice. Seeing that bit of yours makes me think chocolate brown isn't the original color. Yours has more of a metallic sheen to it.
