Old work box for 2" thick walls
Paulski
Anyone know of an old work box that will work with 2" thick walls?
I am adding an outlet above the kitchen counter, and the wall is 2" thick from the tile back splash
P
Paulski
What is 2"? The thickness of the wall, the cavity, or the distance from the face of the wall to the back? There are some specialty boxes that are available.
The wall is 2" thick (tile, mortar, some sort of backer board/drywall), the cavity is is ~5 1/2" deep from the face of the tile to the back of the wall cavity
sparky 1971
Central Iowa
There are plenty. It's going to require a trip to the nearest box store. Don't forget that all kitchen counter receptacles are supposed to have GFCI protection. I don't think a GFCI receptacle will fit in a shallow box, but I've never tried.
https://www.homedepot.com/p/Carlon-...ical-Switch-and-Outlet-Box- 117RSWR/202077341
The Cobbler
I think OP means his wall veneer is 2" thick and a 5-1/2 cavity . the issue is mounting the box to the studs.
can you get in to add some wood blocking or something to secure the box to? or secure a block by screwing from the other side of the wall to mount the box on? or mount a cleat to the back of the wall with screws to mount the box to ?
P
Paulski
I am using a GFCI, I got a 3 1/2" deep old work PVC box, but the tabs only go back 1 1/2" so it wont reach behind the mortar to clamp. Longer screws will push the tab way past the track they ride in that keeps them vertical.
I saw the metal boxes with the plaster ears, but I don't think there is enough tile to drill and use wall anchors, plus the GFCI wouldn't fit in the box, the ground screw stuck out to far and hit the bottom of the box
dave*99
Coastal NJ
Metal box with Madison bars. No wall anchors needed.
gahrajmahal
Cincinnati, Ohio
I think I’d mount my GFCI in a water tight box under the sink cabinet, then daisy chain the others from there. I like the looks of that smart box. Where do you buy them?
sparky 1971
Central Iowa
I misunderstood the original post, you explained it while I was making my post.
Use longer screws for the pvc box? I'd get one of these and use a longer screw. I do it with old work light boxes all the time. You could also shorten the bracket with some snips.
sparky 1971
Central Iowa
I've seen long Madison bars that would work with two layers of drywall, but I don't think they would work with 2" wall covering. I have the standard depth on my van and I know they won't work.
dave*99
Coastal NJ
Most are 1.5”. But the photo I posted are 2.5”. That might work. But if a stud is there a smart box would be good.
P
Paulski
The Allied box looks like it may work with that style of clamp on the back, Thanks!
P
Paulski
I was concerned the screws wouldn't go into he studs to well due to the wall thickness, but I'm thinking I could mount that box further back so it screws into the studs and add a box extender to bring it flush with the wall.
I just found this while googling box extenders, it looks like it extends the old work tab guides too so it might work with my original old work box I was trying to use
sparky 1971
Central Iowa
If you're on a stud, just get a regular nail on box, remove the nails, and cut the nail slots off. Then you can run your own screws through the side wherever you want to. I was doing that years before I ever saw the screw on type box.
sparky 1971
Central Iowa
I didn't know the deeper style were 2-1/2". I do know that nobody around me carries them and I haven't seen any in years.
Zeke
Technically ( I hate to cite code amongst professional electricians, but the homeowners must be made aware), screws aren't allowed inside a box unless it was designed for them like the example above. Have I ever used screws from the inside? I'll plead the 5th.
sparky 1971
Central Iowa
Sometimes ya gotta do whatcha gotta do. It probably shouldn't be done with a fiberglass box though.
Using a drywall screw in place of a 6/32 to install a device is also a code violation but I've done it and so has everyone else.
Zeke
Now that you bring that up, no pointed end screws can be used on any device if they enter any enclosure containing wires. Again, for the posterity should those reading in the future come across this thread about attaching a box.
I really like that box with the saddle bracket in back. Been awhile since I've seen one and there isn't one in my bin of boxes.
sparky 1971
Central Iowa
Now that you bring that up, no pointed end screws should be used on any device if they enter any enclosure containing wires. Again, for the posterity should those reading in the future come across this thread about attaching a box.
Fixed it for you. The screws don't enter the standard plastic/pvc/ fiberglass boxes. Some metal boxes and mud rings, yes, but drywall screws don't work worth a pinch of **** in those anyway. Gonna have to use longer 6/32's on those.
Anyway, I started screwing a standard two gang box to the stud after I would remove a single gang when replacing a standard light with a ceiling fan/light or putting a quad receptacle in place of a duplex. I don't believe a smart box was a thing yet and the existing hole was always too tall for an old work box. Then Arlington came out with the One Box, much more user friendly than smart boxes. I keep two vertical and one horizontal single gang, two two gang and one three and one four gang on my truck. The problem is finding them. Menards used to stock one and two gangs but switched to Southwire. I order them in by the case from the supply house. If I didn't have one, I wouldn't wait for it when I could make my own, even if it is breaking the rules a little bit.
sparky 1971
Central Iowa
I was thinking of non blunted sheet metal screws on some panels where they don't go outside the panel.
You said device. How many devices mount to panels? I see pointed sheet metal screws in panels all the time, but I don't do that one. I find it funny when a home inspector takes them out and won't put them back in. I keep a bag of Square D panel screws on hand for those $150 jobs. A Siemens or Eaton panel may not be listed for a SQD screw, but they fit.
mm08822
Good find.
Make sure you have the correct box extender style. It appears there is an old-work box style extender (the one you want - pic on left) and also a new-work box style extender. Part #'s are very similar. Googling returns both styles under same number. You want the style with the track for the wings.
No mention of longer screws provided for the wings. May need to purchase separately?
Worst case, go back to a steel old work box and cut your own dog ears long enough for the job.
Norcal
I use a thread insert, Heli-Coil is one brand, on plastic boxes so that the OEM screws can still be used.
u2slow
BC
I would probably go for a 4x4" metal box and extension. Screws from the inside into a stud. Use a flat mud ring and a square cover plate. If desired, use 2 gang equivalents for 2 devices.
sparky 1971
Central Iowa
I've never seen heli coils that small, but never looked either. I haven't used very many drywall screws for devices, usually on a worn out fiberglass box, but I think every smoke detector I have ever installed (1000's) has been mounted to a single gang box with two 1-1/4 drywall screws.
Norcal
Not easy to find, needed 8-32 inserts for a Rockwell 1"X42" sander grinder that a screw holding the motor fan shroud had sheared off on & finally found it at one of the local NAPA branches. Not sure I have enough of the sanders though, have 3 1/2 of them, & hard to find parts for.
Zeke
I bought a metal lathe from a guy that used to work on model airplane motors. The sellers gave me most of the tooling some of which I never had ID'd. In the mess were many tiny insert coils for those motors. AND the tool to run them in.
Sorry Sparky, I don't always get the terminology right. and I forgot to mention I was speaking of the covers on panels, outside and deadman. I think there are a lot of incorrect deadman cover screws out there.
SlappyWhite
Upper Canada
Do you have anything like these available?
They are pushed in and they spring open inside the wall. You then tighten the centre screw (between the ground screws) to lock it in, they are very solid once mounted. May work with the current wall thickness, if not just use a longer middle screw.
dave*99
Coastal NJ
Just for completeness, here is the link to deep Madison bars. As always YMMV.
That said, there are other viable solutions in this thread that would work well.
