We’ll get to it man! You sucked me into this years ago and I just got caught up today. You’ve got some slacking to make up for
The addition turned out spectacular and the toys are just too cool to see. Very impressive my friend
Thanks for the comments, Cam! I pretty much have written up the remaining posts and have most of the pictures, so will continue with posting up the vehicles in my collection.
In 2017, I got the itch to see if I could find a 1966 Dodge Charger. I had a yellow/black 383 2-bbl automatic car as a senior in high school. I found a car via cars.com just before Memorial Day in MO that was the same color/interior combo, but was a 383 4-bbl, 4-speed. I showed the listing to my family, who all voted that I needed to investigate further. After Memorial Day weekend, I went back to cars.com to get contact info, and the listing was gone!! He who waits . . . . . . . . .
A month or so later, I decided to do another search. The same car showed up again. So, I called the listing for more info. The owner began by grilling me – “Are you a consignor or agent? Are you looking to flip the car?” – and other questions along the same line. After I explained to him that I had the same car in high school, he lightened up and talked to me about the car. It had gone through a fairly complete restoration prior to his ownership and he was looking to pass it along to someone who would appreciate it. So, we made a deal and my buddy and I made a road trip to bring the car home.
I knew when buying the car that a couple of its unique features weren’t working properly. The first was the rotating headlights. I worked with Topher McGinnis (
www.headlightmotorman.com) to get new relays, limit switches, etc. and to rebuild the rotating motors. I got everything back together and it was working for a while, but needs some more attention. I think the aged wiring in this car is getting in the way of them working properly all the time.
When purchased, the car had an ugly wart of a hood scoop and flat black accent paint on the hood. Worse, whoever did the hood decided they needed to make it “cold air induction” by cutting a big hole in the hood. So, the search was on for a replacement hood and I had a local body shop metal finish the hood and paint it body color. Much better . . .
At some point, I noted the brakes were very “squishy”, and upon repeated inspection, the single pot master cylinder kept losing fluid. I couldn’t find where it was leaking – all the wheel cylinders were dry and there was no evidence of leaking around the master cylinder. I ultimately determined the master cylinder was leaking into the interior compartment. Now, I have brake fluid saturating the jute backing to the carpets and the carpets themselves. I took the backing out and washed it many times, as well as shampooing the carpet repeatedly to remove the brake fluid. I decided to upgrade the braking with a power booster, along with front disc brakes from SSBC. I also completely replaced the brake lines. It stops much better now, but still needs some fine tuning.
The Charger also had manual steering, with many turns lock to lock. I installed a Borgeson power steering kit, and the steering is now much more responsive.
The early Chargers have tail lights across the entire rear of the car. While not available from the factory, I thought this just called out for sequential turn signals. I found a company (
www.easyperformance.com) that makes a LED conversion kit for the car. The old taillight lenses were pretty crusty, so I was able to find new lenses to go with the LED conversion. The rear lights are much brighter now, and the sequential function is programmable to several different configurations.
One of the neat features of this car is the electroluminescent dash, where the pointers and numbers, etc. light up instead of being backlit. Many of the gauges weren’t working properly, and only a portion of the electroluminescent dash was lighting up. Again, I found someone who created a solution for these issues. Mark Gibson (
www.thegaugedoc.com) came to the rescue. I sent off the gauge cluster for recalibration and to have the electroluminescent system redone. Everything has been returned, but I haven’t yet done the install. I was stalling to make a decision about adding Vintage Air (I won’t be in this car), and will likely do a bunch of rewiring of the car along with the gauge package install. Additionally, it appears that when they media blasted the car during restoration, they didn’t remove the rear window, nor did they mask it completely. So, the glass is badly pitted and won’t polish out. That’s another project, along with swapping out the speedo gear to try and get it to read correctly. I hope to document these projects here as they get underway.
