Museum-Quality Concrete/Construction
strutaeng
Dallas, TX
I know, not really a garage related topic, but it's a concrete topic... :)
I see a lot of threads about concrete like strength, finish, durability, etc. Lot's of folks see a little crack on their newly-poured concrete slab and ask if the sky is going to fall, etc. On some threads I've mentioned the term museum-quality concrete. What exactly is that anyways?
Last week I chaperoned to my kid's field trip to the Kimbell Art Museum in Fort Worth, Texas. For those that don't know, the Kimbell is a world-renowned building built in 1972 and designed by Estonia born Louis Kahn. It's a relatively small building composed of a series of these post-tensioned cycloid vaults. Spans are like 100' or so. Very simple and elegant design. This was early post-tensioned concrete.
In 2013 the Renzo Piano pavilion was completed across the lawn of the same property. Actually my first time going to the Kimbell since this part was completed. It's a different building, slightly different materials, but pays a tribute to the original building. The concrete is incredible, similar to the Ft. Worth Modern Art Museum just across the street from my memory. I know that getting this quality of concrete takes an enormous amount of effort, from design, concrete supplier, contractors, subs, etc., not to mention cost, hence why I've called that, museum-quality. Anyways, I just snapped some random photos with my phone, nothing really specific. I'm certainly not a concrete materials expert, but I have worked on some cool projects similar to these on the consultant side and have learned how some of these unique buildings are put together.
So if you find yourself in some museum kinda bored, look around and check out the structure...whether concrete, steel, timber. Better yet, if you are in the area, stop by and check this out, as well as the other museums all within walking distance of each other.
ConCretin
Central Maine
That’s not craftsmanship nor museum quality, that is a ”sack and patch” finish. Easily achievable on any concrete if someone wants to pay for it.
With all due respect, that is a ridiculous and uninformed statement. That is an as-cast architectural concrete finish, which required meticulous design and craftsmanship to construct....... not to mention an obscene amount of money.
whateg01
doo dah, kansas, usa
Is that not largely a function of the forms used? The forms we used when I did foundations were beat up, rough, had remnants of previous jobs left behind. When I made a concrete pedestal for a piece of yard art last summer, I smoothed the forms I used and applied a mold release (hair spray) and the pedestal came out smooth.
Snapped-off
Indiana
When people want a 20k concrete job budgeted down to 5k, I'm sure you'll probably lose some of those fine details..
ConCretin
Central Maine
Form facing materials are part of the equation but form design is also critical. Every form element must be designed for minimal deflection. In addition, the forms need to be virtually waterproof to avoid mix water from escaping, which creates color variations and sand streaking. The carpentry needs to be of finish quality. Panel sizes and tie layouts need to be arranged symetrically. Then there's crack control. A rich, free flowing mix with properly sized aggregate is important as is extremely thorough vibration.
This type of concrete is orders of magnitude more difficult than the average structural wall. You literally need to get it right the first time because invisible repairs are extremely difficult.
Rusted Nut
PNW
Do you know for sure that is “as cast”? If so, then I retract my statement. I have never seen concrete like that with some post pour finishing.
strutaeng
Dallas, TX
Thank you @LLWillysfan ...I would hope you'd chime in.
@Rusted Nut definitely as cast. I know what sack and patch, parging, rubbing, etc. looks like. Not stained either. None of that here. Actually, I don't even recall seeing any shrinkage cracks! Unbelievable.
I'm not sure on the form work. I believe they use some MDO or phenolic overlay plywood. Very likely a one-time use? On some of these projects a mockup is almost always required and usually part of the contract requirements.
We just finished a project with board-formed concrete smallish retaining walls (although it wasn't architectural exposed concrete). We required a mockup and the contractor wound up doing two of them to get the desired grain effect on the concrete from the wood forms . The concrete sub still struggled with a bit of honeycombing on the actual walls. Obviously wasn't anything near what the Kimbell resembles, it was more like a rustic look. Likely will get grafitti as it was in a public park. LOL
Just to clarify, I'm not implying that this kind of construction is ONLY found on museums. I've seen some really high end homes with this type of construction. But unless you live in one of those homes, you probably would not know. On the other hand, museums are open to the general public so that's what anyone can relate to ☺️...just gotta keep it down on the noise, as our third graders quickly found out.
Nothing really like this on your typical tilt-wall concrete panel warehouse, retail, cast-in-place or precast parking garages, or commerical buildings that I can recall; those buildings typically get an architectural "finish" (we call that a "fu-fu finish", except parking garages and warehouses. Some hospitals or university buildings may have a similar marquee building or even a museum on their campus. Whoever is the pilatrophist with the highest donation would get their name on the entrance of that building.
ConCretin
Central Maine
First off, Rusted Nut, I'd like to apologize for my snarky response. It was unwarranted.
It's definately an as-cast finish. You can see the sheen imparted by the smooth form facing material and there are still tiny air pockets still visible, all of which would be obscured by any subsequent finishing operations. They obviously had to patch the tie holes and I'm sure there was a little rework required here and there but most of that concrete looked like that right out of the forms.
A 'sack and patch' finish involves patching defects & tie holes followed by the application of a loose mortar onto the surface. The excess mortar is removed with burlap or the edge of a steel trowel. This is done to fill all the air holes and provide a more uniform color but it doesn't hide much.
The point I was trying to make was that the entire approach to architectural concrete is fundamentally different than it would be for a basic structural wall. It wouldn't be uncommon to sack an architectural concrete wall but it's not going to change a sows ear into a silk purse.
CSRPenFab
Meridian Idaho
Very nice. Years ago, I got to do some fire protection engineering work at the Jonas Salk Institute in Torrey Pines near La Jolla CA. The campus is on a cliff over the ocean with amazing views. Kahn built this masterpiece in the 1960's, and it's amazing. The modular research labs have "interstitial" spaces between each floor and are plumbed with Pyrex glass piping for all the various hazardous chemicals used there. Lots of nasty stuff like Aids research, so bio security is really strict.
It's an amazing building and I highly recommend a free tour if you're ever in the area. Interesting thing is the primate research lab that is built fully underground to keep the animal rights protestors at bay.
Rusted Nut
PNW
You are forgiven for being snarky. I guess my initial post was a bit snarky as well. I’m a commercial superintendent and have done a number of projects where the contract documents state as cast finishes, and then owner hates the finish and demands it be re done to look like such and such a project, that was a sack and patch or similar.
Taking a better look at the photos, yes I see the pin holes and such, it is “as cast”. A nice job at that!
Stuart in MN
Minneapolis
Looks like it's held up well too. 20 years isn't necessarily that old for a building, but we've all seen exterior concrete work that looks pretty lousy after just a few years exposed to the elements.
kyrbz
midwest US
I love concrete construction. I'm kind of a connoisseur of Brutalist architecture. Another great concrete museum in my neck of the woods is Tadao Ando's Pulitzer Arts Foundation in St. Louis, MO. First pic isn't mine, but the rest are from my visit when it was hosting the Ruth Asawa Retrospective in 2018.
kyrbz
midwest US
Another great piece of concrete architecture I visited recently is Pritzker Prize winner Kenzo Tange's mid century modern brutalist masterpiece, the Kagawa Prefecture Government Hall on the Island of Shikoku in Japan. Completed in 1958, it still functions as the Kagawa Prefecture Hall but now houses an exhibition on the first floor with drawings, models, photographs, and construction mock ups dedicated to Kenzo Tange's life work.
kt2.jpeg kt3.jpeg kt4.jpeg kt5.jpeg kt6.jpeg kt7.jpeg kt8.jpeg kt9.jpeg kt10.jpeg
bb29510
the biggest problem with quality concrete is when the contractor says, all concrete cracks, he needs to be fired, a boot up his *** and thrown off the nearest cliff. it cracks because his labor *****, his craftman *****, and he stupid
Fixr
SW VA
Yeah, I kinda came to that conclusion after walking through airport terminals and other huge spaces with acres of uncracked concrete floors and very few expansion joints, much less saw cuts.
niget2002
Josephine, TX
Wife and I went to an exhibit there many moons ago.. pre-kid, actually.
We need to plan another trip over there. It makes for a good day trip.
kyrbz
midwest US
Not a museum or even architecture, but I really like tetrapods for some reason. Pics were taken in Yonago, Japan
NORTON'S SHOP
Upper Midwest
http://www.american-artstone.com/
Check out the above website. Most; if not all; of the work shown in this thread would never be allowed to go out their door.
ConCretin
Central Maine
I wish you hadn't picked that statement to quote. lol. It was so snarky I felt the need to apologize.
In fairness, there is a huge difference between constructing a structural cast in place element on a job site and a precast decorative item in an offsite plant. With that said, the best examples of each method wouldn't be that far apart.
whateg01
If every general contractor or foundation crew took the time and effort and paid week enough to have the kind of people that can make great work happen, it would be too expensive for most people to swallow.
kyrbz
midwest US
I recently did a tour of the Metropolitan Area Outer Underground Discharge Channel in Saitama, Japan. It's the world’s largest underground flood protection system designed to keep the greater Tokyo region from flooding. Construction started in 1992 and was completed in 2006. It consist of several huge underground concrete silos strategically placed around Tokyo that are 213' deep by 106' diameter. The silos are all connected by underground tunnels so that if one silo is receiving more water than the others, the water level is equalized through the tunnels. The last silo at the pumping station has a large opening in the side that allows the water to flow into the "tank" which is a room 581' long x 256' wide with the ceiling supported by 59 - 83' tall pillars. From the tank the water is pumped out by 78 - 13,000hp pumps that discharge 200 metric tons of water per second. The scale and amount of concrete in this project is hard to comprehend. The tour starts above ground at the control center pumping station. They have a scale working model that actually fills up with water and pumps it out to demonstrate how the system works. There is also a scale model of the boring Machine used to connect the silos to the tank/pumping station. The tours then proceeds to the tank room and finally partially descends the last silo connected to the tank.
kyrbz
midwest US
These pics are mostly from the above ground control center pumping station with the models. The second to last pic shows the control center from the outside. The "tank room" is below the large field in the foreground of that pic. There is a large access door that bulldozers and cleaning equipment are craned down for cleaning and maintenance. The last pic is looking towards the entrance to the last silo in the system with Mt. Fuji in the distance
PopcornSutton
Northern Tip of VA
What a wonderful old thread, before my time here. Glad it was brought back up again. Having done a fair amount of concrete form work myself, the attention to detail in the forms can't be stressed enough. When CC mentioned the forms are like finish carpentry, he is right! Any and all mistakes or imperfections in the forms will be transmitted to the finished wall. Even the slightest hammer mark from nailing chamfer strips will be seen. The design of the forms is huge. The tie layout is unavoidable, but can be done where they look like there are supposed to be there. The support/framework which isn't part of the finish face, is just as important to prevent bowing and pillowing. But all the great form work is for not if the placement isn't proper. The rate of pour, the ******** men, concrete supplier all play just as important part. Very challenging construction.
bb29510
alot of that is the twenty foot rule, you cant stand closer than twenty feet to inspect it. yes, Im being serious, its in the spec. also we use a lot of chemicals in out concrete. mid range water reducers, High range. Ice. chill water. etc its not your father concrete mix. 4000 is the basic mix and its about $160 a yard
PopcornSutton
Northern Tip of VA
The 20 foot rule is used for masonry work much more often than poured concrete work. You can't hide mortar joints whether left as a finished wall or painted, the joints are still there. And considering most masonry work done today, they should make it 50.
The thread referenced "museum quality" concrete work. That just negated the every day acceptable work.
bb29510
im sorry, I been doing quality control of concrete for 43 years now, I guess I need to call my boss and tell him the 20 foot rule is BS and we need to stop doing quality contro
PopcornSutton
Northern Tip of VA
Read my last sentence. It doesn't matter if it's concrete or masonry, if work is specified as museum quality, things change.
Joemctag
Outside raleigh nc
And because mock-ups (samples) would be required to be acceptable to the architect, a contractor who wasn’t up to it wouldn’t go on to do the work. You only get one chance if you don’t want to demolish and re-do.
