600SL
I'm putting 200 amp service off to my garage. Since it is being feed off the house 320amp meter it just requires an LB at the garage. I'm using 2.5" PVC conduit so I need a 2.5" LB at the garage. I found there are 2 different types of LB's, LB and SLB. Do I assume I have to use the SLB since it is a service entrance to the garage. Difference in cost is between $100 to $200.
www.iesupply.com
Halex 2-1/2 in. Aluminum Rigid Threaded Conduit Body 58625 - The Home Depot
The 2-1/2 in. Threaded Conduit Body is designed to gain access to the interior of a raceway for wire pulling, inspections and maintenance. The elbow has a cover and gasket for easy access. It is suitable
www.homedepot.com
Killark SLB-7 2-1/2" LB Hub, Aluminum Service Conduit Body | Independent Electric
www.iesupply.com
