Above 1200 Sq/FT The Fort!!
bustdnukles
Naples, Florida
Fun.... BTW, I'd look at the contents of the box that was on the rear stack, as it looks to have been crushed on the one piece of dunnage.
Myself AND the Driver went over everything! He told me the last one he delivered, took a crew of FOUR, 10 hrs to off load! We did it in 3.5!! He was the best, even helped me with some damaged stuff,(poor packaging of the siding), which in turn, got 17 panels replaced!! They showed up 2 days ago, to my astonishment!!
bustdnukles
Naples, Florida
One pays one's money and makes a choice. We ended up digging down to good inorganic soil, but the site became a swimming pool. Ended up with a footing drain around the building, and daylighted it down the hill:
I had to bring in all the fill PER county code! Errrr. I'm in a 500 yr flood zone, so they say.
LopezBart
Lopez Island, WA
Unfortunately that is so true. Our society has made it so that if you work at a trade you are a second class citizen. Try and find a good machinist or machine shop.
I've had the pleasure of working with good machinists years ago at LLNL, UC Davis, FMC Central Engineering Labs, etc. They were respected by their bosses, were skilled at their jobs, and gave this wet behind the ears engineer plenty of **** :). Check out a micrometer from the Ag Engineering toolroom to check some abused shafting, and the foreman sees me and says "You know that's not a C-clamp, right?". I forgot to put the material on a drawing of a hydraulic pump drive for a hybrid car (even though I handed them the Al tubing I'd found surplus) and I get asked if I want it made of clay.
Anyway, there are plenty of good machinists around - they're probably not working in an automotive machine shop, however.
cvairwerks
Within hearing distance of Texas Motor Speedway
Think it's bad trying to find anyone doing machine work, try getting anything done for an an antique airplane... Most of the time, they don't even let you clear the door before slamming it on you!
bustdnukles
Naples, Florida
Looks like you have a slight lead over your neighbor's project, are they building a shop too?
You wouldn't believe me if I told ya!! Ok, I give! SOMEONE paid $1.7m for 2.1 acre w/ VERY nice house, STOCKED pond, all sorts of trees and plants, only to tear it down, fill in the pond! Thankfully they left the bamboo and myrtles that lined the perimeter. Supposedly putting up a McMansion, guest house, and small shop. Unbelievable!
bustdnukles
Naples, Florida
You wouldn't believe me if I told ya!! Ok, I give! SOMEONE paid $1.7m for 2.1 acre w/ VERY nice house, STOCKED pond, all sorts of trees and plants, only to tear it down, and fill in the pond! Thankfully they left the bamboo and myrtles that lined the perimeter. Supposedly putting up a McMansion, guest house, and small shop. Unbelievable!
Dan in Pasadena
Pasadena, CA
Jose on the power trowel! All the trucks are gone! Now we wait...28 DAYS! Errr! I have plenty of other stuff to do! LOLIMG_6136.JPG
Why are you waiting? Your engineer can tell you that concrete typically develops 90% of design strength within 24 hours. Also typically, it will far exceed the design strength when it's done curing. If you used say 3000 or 3500psi concrete it'll likely end up being well over 4000 or even 4500 psi when cured.
dmittz
That sorta thing is very common here, but its amazing regardless.
LXCam
That next step alone is going to be a major time ****. I sure hope you got plans for an extended reach forklift and a buddy that can run it.
meathooker
Iowa
its 90% in 7 days.
LXCam
Bro that’s aggressive by yourself :bowdown: I’d suggest you leave the bolted connections loose on the purlins so you don’t screw yourself aligning the header with the column if you keep going. Personally I’d complete the header full span then layup your purlins after you’ve squared up the building.
