Best, cheap bench drill press?
hailwood1965
I'd like to get a new, small bench drill press.
Initially I'd like to use it to drill holes in small bolts and nuts for safety wire.
Any recommendations?
I'd like a designated unit, not one that uses a drill or a dremel.
Screenshot 2024-03-03 at 14-37-52 hobby drill press on bench - Google Search.png
ohhimark
detroit
If that's all you plan to use it for then the average bench top press should suffice. It will also fit on the bottom a floor-standing drill press after you upgrade.
isb cornbinder
The bottom of the line drill presses are about the same. I would advise taking a mag-base dial gauge with you when you go shopping. Buy the drill press that has the least amount of run-out.
ColoradoMech
Denver Colorado
The biggest issue Ive had with smaller drill presses is the belts slipping when drilling through steel with larger bits. If your just drilling safety holes in hardware, any of those small presses should do if you have half decent cobalt bits. I personally like the HF ones because you can use it then return it if you really want to. But for $80 for a drill press it is just worth hanging onto afterwards for the next small project.
hefnerconstructionlc
Kansas
I had a craftsman one like those and it worked really well till I accidentally broke the work table. I upgraded to the Menards for variable speed. It is great.
cannuck
Rural SK
Almost every low buck 1/4" drill press is about the same. I use mine a fair bit. Typical el cheapo with a 1/4" keyless chuck that cost more than the press, but with a decent vice and chuck it is extremely usefull for small holes. My other presses all have 1/2 to 3/4 chucks and can't turn nearly high enough RPM for tiny bits, so a useful tool.
johnre
Portland, OR
"Best" and "cheap" are usually mutually exclusive, of course.
Small benchtop units often suffer from too small a motor, short quill travel, reduced clearance between support column and drill chuck, and not a lot of speed selection.
If you want more value for a limited outlay, consider getting it used with at least a 1/2 HP motor, 14-15" clearance, and two belts / three pulleys. Grizzly makes a good one, G7943, that's 14", 3/4 HP, and speed selection from 140 - 3050 RPM.
catalytic
Boston, Los Angeles, Cleveland
No, just when you're buying new.
OP, the best drill press you're going to find is a $50-$120 American drill press made by Delta or Rockwell or about 30 other manufacturers between 1940 and 1980.
I rebuild machine tools and there is just no comparison between those and what you're looking at. For one, they are made of metal parts, which helps when you want to use them to make holes in other metal parts. Also, the chucks on most of the drill presses you linked kindof ****. Using them is an exercise in frustration.
Post a wanted ad on OWWM.org. Most of us have too many bench drill presses lying around. Decent bench drill presses are the opposite of rare and expensive... most of us jump at the chance to free up bench space.
NUTTSGT
Northern Central Ohio
I think would would check out Govdeals for something that is used but a better unit. Nothing wrong with buying a good used tool.
Davefr
OR
I agree. CL usually has plenty of older bench top DP's. Even the older Taiwan machines were decent.
bassJAM
Cincinnati, OH
I've had a WEN for about 10 years I'm happy with. It does retail more expensive than the HF unit, maybe $200ish but I got it as an open box at a heavy discount.
Renegade1LI
long island ny
I've seen a few powermatic bench top 1150s and they seem to go cheap. Some come with a nice steel bench they were mounted to.
Jeff
Sonova Beach
I bought a Grizzly about 20 years ago. No issues. Parts are available. I did upgrade the depth guide when they updated the new press.
larry_g
oregon
I'd advise you to review and understand the process for safety wire drilling. One thing is that for that small of a diameter hole your going to need a high speed spindle. Some of the really cheap presses may advertise a high top speed but lack the power to really turn it that fast. If your turning at the speed required by the small bit then balance comes into play. Do a search on precision or sensitive drill press to see what is out there. Where in the world are you? I may have what you need.
lg
no neat sig line
  • Like
Reactions: RTM
lafester
Northern CO
I absolutely love my 1150, but I think the op is looking for something smaller. The delta dp220 is fairly common and easy to manage.
sparky 1971
Central Iowa
I have the Masterforce branded drill press sold at Menards
It appears to be the same as the Harbor Freight 12"
I don't use it very often, but when I have, it's always done the job.
