hailwood1965
- Joined
- Nov 28, 2014
- Messages
- 165
The bottom of the line drill presses are about the same. I would advise taking a mag-base dial gauge with you when you go shopping. Buy the drill press that has the least amount of run-out.
No, just when you're buying new."Best" and "cheap" are usually mutually exclusive, of course.
I agree. CL usually has plenty of older bench top DP's. Even the older Taiwan machines were decent.No, just when you're buying new.
OP, the best drill press you're going to find is a $50-$120 American drill press made by Delta or Rockwell or about 30 other manufacturers between 1940 and 1980.
I rebuild machine tools and there is just no comparison between those and what you're looking at. For one, they are made of metal parts, which helps when you want to use them to make holes in other metal parts. Also, the chucks on most of the drill presses you linked kindof ****. Using them is an exercise in frustration.
Post a wanted ad on OWWM.org. Most of us have too many bench drill presses lying around. Decent bench drill presses are the opposite of rare and expensive... most of us jump at the chance to free up bench space.
I absolutely love my 1150, but I think the op is looking for something smaller. The delta dp220 is fairly common and easy to manage.I've seen a few powermatic bench top 1150s and they seem to go cheap. Some come with a nice steel bench they were mounted to.
