kerrynzl
Squinting helps a lot![]()
You're only focusing on your sewing [have a look at the overall job]
If you ever pulled apart any manufactured furniture, you'd swear they used a "seeing eye dog" to help them sew.
Here is my latest work ! One of these "It pissed me off so I finally needed to fix it" Jobs
I do a bit of Dumbbell weight training on a bench at home.
Whenever I finish a set, I sit up and lower the weights to the floor. But the problem is my dumbbells kept catching on the pockets of my tracksuit pants.
This resulted in twisting wrist injuries and ripping the tracksuit pockets. [65lb dumbbells always win]
So I was going to sew the pockets shut, then I had an idea. ......... Sew some zips into the pockets
I had some leftover continuous chain zip and a couple of sliders so I sewed these into the existing pockets [after unpicking the ends]
Sewn blind from the under side [while inside out]
Then I turned it back in and threaded the sliders on !
And sewed across the ends so the sliders wouldn't come off
I should've done this months ago
While I was "on a roll" I decided to sew the thumbs on my training gloves back together [I use cheap cyclist gloves]
So don't look too closely ! This ^^^^ isn't my proudest work [Fine Craftsmanshit
