Qualitytools
You can find super lube in a tube at Harbor Freight among other places. You want to stay away from petroleum products.
It seems that Super Lube is also designed for o-rings, so like @Etchase said they will be similar. I suggested Molykote as its easy to purchase in Europe.In compare to Molykote 55 is this better?
Coffee machine grease comes with very small packages like 5gram if you use it in very small amounts per year. Its silicon based and it has to be neutral for both o-rings and plastics (also food grade). But if you work with automation or as mechanic than even 100g tube goes down quickly.This is what I use also. The problem is that it only comes in a giant tube and, because of that, it's expensive. I really wish it came in a "travel size" tube instead of the mega-family tube. Even if I live another 100 years, I'll never use it all at home.
Yes, that is true. Molykote 55 is silicone based, and is not compatible with silicone o-rings. The preferred chemistry for silicone 0-rings seems to be PFPE.Hello, I want to lubricate some silicone O-rings and I read on the internet that the silicone grease if applied on silicone O-rings or seals can swelling or softening them. Is that true and if yes which grease type is the proper for silicone O-rings or seals lubrication?
Knipex factory tour
I want to lubricate the new silicone O-rings (I bought silicone O-rings because I beleive are more durable and last longer or I made wrong and I had bought "ordinary" O-rings?) from my desoldering pump. Which type/number would you suggest me to use for this purpose (if anyone knows any other brand of PFPE grease where is available for selling in europe, please post it)?
MOLYKOTE® HP-300 Grease
NLGI Grade 2 - Linear PFPE based grease with a base oil viscosity of 160 cSt at 40 C, PTFE thickened, uses PTFE as solid lubricants.<br><br> HP-300 Grease has been tested by BAM and approved for the use in oxygen rich environments e.g. in pumps, valves, compressors. The test results ensure that...www.dupont.com
MOLYKOTE® HP-670 Grease
NLGI Grade 2 - Linear PFPE based grease with a base oil viscosity of 85 cSt at 40 C, PTFE thickened, uses PTFE as solid lubricants.www.dupont.com
MOLYKOTE® HP-870 Grease
NLGI Grade 2 - Linear PFPE based grease with a base oil viscosity of 350 cSt at 40 C, PTFE thickened, uses PTFE as solid lubricants.www.dupont.com
Choose the one that has the most appropriate base oil viscosity (85, 160, or 350 cSt) for your application.What part number of MOLYKOTE would you suggest me to apply. Also, if you know another brand of PFPE grease where is available for selling in europe, please post it
Low viscosity oils generally work better at low temperatures, while greases with a higher base oil viscosity are used more for heavier loads and higher working temperatures. It is also important to consider the speed/revs per minute of the application. Low speed calls for a high viscosity base oil, while low viscosity oils are to be preferred in fast-moving applications.
How to choose the right type of grease
Water, dirt, chemicals, temperature, operating speed and load are all examples of parameters that need to be considered when choosing a product.www.fuchs.com
I don't understand. Why can't you find what you want with an online search?Many thanks for your reply and for your useful link, but could you suggest me a different PFPE grease brand because the price of these MOLYKOTE greases are very to extremely high (or I am serching on the wrong sites).
A google search for "PFPE greases" turned up this, and others:
I have used the current version of these.
short production video of the new Hazet pliers wrench
The features you mentioned are already built in .... If you remove the black grips there should be a blue grip underneath and if you remove the blue one you have your chromed handlesBut come on Hazet - I expect the grips to be "Hazet Blue", not some generic black! In fact, how about an option with chromed handles (which no other manufacturer offers) so I can use them in really grubby environments! This was an option on Hazet pliers historically!
I don't have much Hazet, but can confirm some other European tools do have such marks. Since there's no functional difference, it seems to just not matter to certain brands. Hazet does not sell much in stores, mainly bought through dealers, so aesthetics aren't a key selling point to them like they are to some US-focused brands.Looks well made. I have the Knipex 250mm version but am a bit wary of Hazet's cosmetic finishing. This is my new 14mm LG wrench. Is this acceptable in Germany Monte?
I have quite a few European tools. While some, German in particular, sometimes have a few grinding marks, I generally find the quality of Hazet to be first class. In this instance, the mark looks to be from the forging stage, it's obviously a defect, and I wouldn't be totally happy.I don't have much Hazet, but can confirm some other European tools do have such marks. Since there's no functional difference, it seems to just not matter to certain brands. Hazet does not sell much in stores, mainly bought through dealers, so aesthetics aren't a key selling point to them like they are to some US-focused brands.
Agree, especially for what you pay for.I have quite a few European tools. While some, German in particular, sometimes have a few grinding marks, I generally find the quality of Hazet to be first class. In this instance, the mark looks to be from the forging stage, it's obviously a defect, and I wouldn't be totally happy.
Correct, if you enlarge the image the nickel and matt chrome was done over the rough forging mark. It also had a ding, done later, in the open end. I sent it back to Amazon for a refund.I have quite a few European tools. While some, German in particular, sometimes have a few grinding marks, I generally find the quality of Hazet to be first class. In this instance, the mark looks to be from the forging stage, it's obviously a defect, and I wouldn't be totally happy.
Hi Matt,My sister lives and works in Switzerland and happens to know a guy who works for PB Swiss. So she got me these for Christmas. Because when I went to visit her, I only had hand baggage allowance, I couldn't take these home till now. Y'all care to guess what they are? Answer at the bottom of the thread:
Also got a very nice set of PBs in a blister pack:
And when I was out shopping, I happened to pass a combined tool shop and model rail store, in Belp, near Berne. Very cool place to spend 1/2 an hour, even if everything was 'reassuringly expensive'. I picked up a Promat 1/4" socket set with my remaining Swiss francs:
And as you've got this far, those PB doohickies are in fact Fondue forks....
Matt
Quoting this reply since it's the newest here on the forum mentioning Heynen.A dude from Heyco once told me: Heyco = Germany, Heynen = Ireland, Heytec = Import. But since i´ve never seen an irish Heynen tool (labeled as "Ireland") i always doubt it.
On the other hand they own a forge in Ireland (Shamrock Forge & Tools in Ballina/Republic of Ireland)....
https://www.heyco.de/_EN/standorte.html
https://www.heyco.de/_EN/geschichte.html
...and it seems they produce tools there too. The internet says car tool kits and DIY tools....Maybe they do produce blanks there which then are finished over here hence they have the "Germany" on the tool because the last finishing steps are made here which is good enough to label it with "Germany". But the customs paper work says "Ireland" because in the US the COO labeling is more stringent...... ?
